Community Member
What phones get connectivity when using SRST 3.0
In the new version of SRST can you control which phones get SRST connectivity? Can this be controlled using the device pool option?
1 ACCEPTED SOLUTION
Re: What phones get connectivity when using SRST 3.0
CallManager 3.3 provides the ability to configure SRST references. Each SRST reference you configure you simply specify the IP address of the SRST fallback gateway.
Each SRST reference can then be assigned to different device pools, therefore you can exclude certain devices by assigning them to a device pool which does not have a SRST reference configured.
I have successfully configured two SRST gateways utilisting the SRST reference feature within CCM. This provides resilency by dividing the IP phones endpoints across two separate SRST gateways.
For your information, the SRST gateways are running 12.2(15)T5 which is using SRST version 2.1.
Community Member
Thanks for the information. This is exactly was I was looking for.
-Colin
102
