When is FastDial on 7912 going to be fixed?
I have CM 3.3.3 sr2 and it still did not fix the problem with FastDial on 7912. Anybody know when the fix is coming out?
Bronze
Re: When is FastDial on 7912 going to be fixed?
I'm on CCM 3.3(2) and loaded up the latest firmware for the 7912 (CP7912010200SCCP030918A.SBIN). I now have services running on the 7912. Corporate Directory works fine. When I select "My Fast Dials" it causes the 7912 to reboot. However, I thought I read that you need to be on 3.3(3) for that to work so I wasn't to concerned (can't find where I read that), but I see you are there and you don't have it working. Do you have the Corporate Directory working?
Here is the bug ID for the problem CSCec53044. The code fix for the bug was done only yesterday; the fix will be posted in CCO shortly.
93
