When it rings more then 40 seconds, callers receive :number is not assigned
My customer does have the following problem : after it rings more then 40 seconds, callers receive a "number is not assigned" message from the E1 provider.
I have the debug isdn q931 in which we can see that our voice gateway sends an :
Cause i = 0x8081 - Unallocated/unassigned number message.
How can I increase this time to about 2 minutes ?
Many Txs in advance !
Dirk
Setup
Callmanager 3.3.3SR4 <-> MGCP <-> Cisco 1760<-> E1(PRI) <-> Service Provider
*Mar 27 23:51:33.227: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x005C
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x21, 0x83, '37450445'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '37146753'
*Mar 27 23:51:33.271: ISDN Se1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x805C
*Mar 27 23:51:33.271: ISDN Se1/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x805C
Progress Ind i = 0x8088 - In-band info or appropriate now available
*Mar 27 23:52:13.293: ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x805C
*Mar 27 23:52:13.381: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x005C
*Mar 27 23:52:13.401: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x805C
Silver
Re: When it rings more then 40 seconds, callers receive :number
We can change the T310 timer on the gateway by "isdn t310 120000" command and check with "sh isdn timers" command. And note that "120000" value refers in msec, so that this changes to 120 sec.
Please refer the following doc for more info...
http://www.cisco.com/en/US/products/hw/vcallcon/ps2152/products_tech_note09186a00801f0934.shtml
Hello, this seems not to be the right timer. Does anyone has got another idea ?
Many Txs
101
