You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Where is Call Detail Records (CDR) Central DB
CDR’s, just want to check where there central database is, is the central db the Primary Server in the cluster (The SQL Publisher).
  • Other Collaboration Voice and Video Subjects
1 REPLY
Re: Where is Call Detail Records (CDR) Central DB
The consolidated CDR database is held on the publisher. Any subscriber cached CDRs are copied up to the publisher and then deleted from the sub. There are only significant numbers to copy up if then has been a loss of connectivity to the publisher! But these will catch up for centralised reporting.
... pdc
107
