Will E&M work with the "Night Ring" interface on a Bogen?
The Bogen documentation states "The NIGHT RINGER feature can be activated from 90V ring signal or contact closure." Does an E&M interface support contact closure? And, has anyone implemented this solution successfully specifically with the Night Ringer feature? Many thanks in advanced!
-john
1 REPLY
Bronze
Re: Will E&M work with the "Night Ring" interface on a Bogen?
Were you ever able to get this to work. I am trying to get an ATA to use the night ring with Bogen and it works internally but not when you call in from the outside. I tried a viking device that supposedly increases the voltage but with no luck??
166
