Community Member
Would 2610 w/12.1 supports Silence Suppression and Echo Cancellation
Would 2610 w/12.1 supports Silence Suppression and Echo Cancellation?
I need to setup a VoIP lab for a client with their existing 2610 running 12.1 IOS.
What minimum RAM, flash, IOS I need on 2610 in order to support both VAD and each-cancel for a FXS card over PPP?
1 REPLY
Anonymous
N/A
Re: Would 2610 w/12.1 supports Silence Suppression and Echo Canc
As long as it supports voice, you need plus feature set image, check the software download on cco
for memory requirement.
84
