WS-6608 Voice Gateway with ISDN PRI compatibility
I have one ISDN PRI from ISP connectted with WS6608 voice gateway but when everytime I reset my module, I will need to request my ISP to start my 30 channel manually.
ISP is Nokia system, ISP said the is because of my voice gateway didn't send the message to Nokia system. So that it will not start the channel automatically.
Have somebody face this kind of problem or any suggestion ??
Fran
Re: WS-6608 Voice Gateway with ISDN PRI compatibility
After you reset your module, are the channels showing OOS? (out of service)? Are you running MGCP/H323? What ver of cm? what load for the 6608?
Try changing the following fields on the gateway config on callmanager:
'Delay for first restart (1/8 sec ticks)' = 33
'Delay between restarts (1/8 sec ticks)' = 3
'Inhibit restarts at PRI initialization' = unchecked
Now reset the module and see if it helps.
Azam
Azam thanks for your support, I have made the changes but didn't see any changes, still the same.
after reset my module didn't any OOS warning.
The protocol that I'm used is Digital access PRI.
My Call manager Version is 3.3.
Do I need to upgrade the IOS of my Cat 6000 ?
Thanks for advisem
Fran
100
