10-20-2005 02:42 PM - edited 03-15-2019 03:46 AM
I have a 6500 with a CMM blade in it is running 12.3(8)XY5
The CCM is 4.0(2a)sr2b
The PRI interfaces are up and registered just fine and working.
It has a mediacard 4 that is configured totally for conferencing, however I could not get it to register with CCM when I chose the Conference Bridge Type WS-SVC-CMM. However when I registered it as a Enhanced IOS Conference Bridge it does however when I try to conference it drops everyone off.
I remove the MRG that contains the CMM resource from the MRGL and just use software and everyhthing works fine.
Does anyone know if there is a BUG that might be casuing this.
10-20-2005 03:07 PM
You have to use WS-SVC-CMM for this type. Can you please do "debug sccp packet" and then, do "no sccp" and "sccp". Then, send the configs, and the debugs to us.
also send us:
show sccp
show mediacard all
show dspfarm all
Thanks!
10-20-2005 03:07 PM
forgot to mention XY5 is deferred. Please use XY6
10-20-2005 03:27 PM
I will get all of this for you tommorrow because unfortunately I am not onsite.
If you can give me an e-mail address to send it to because this is a government facility I would greatly appreciate it.
I have contract numbers if you wish to also make this a TAC case.
Thanks for your quick response.
Brian
10-20-2005 03:35 PM
Also, What is the most stable IOS at this point for the CMM blade?
It will require downtime to upgrade which I will have to coordinate with the site.
Thanks again!
10-20-2005 08:38 PM
I have used XY6 (12.3.8) without any issues (moved from XY4 due to bugs to XY6).
10-21-2005 03:24 PM
Got it to work by adding in a static ARP entry. However I did keep it in CCM as a Enhanced IOS Conference Bridge and no a WS-SVC-CMM because I still could not get it to even register when I chose that method.
Hopefully customer will upgrade to 4.1(3)x and then I can go back and redo it.
Thanks for everyone's replies.
Brian
