WS-X4606-gwy module
Can WS-X4606-gwy module support L3 routing?
the ios image:c4gwy-io3sx3-mz.121-5.YF4.bin. Can the voice gateway module support vlan routing with this ios? is there any sample configuration available?
there seems don't have enough info on this module from cisco web site.
Thanks in advance!
Sara
Re: WS-X4606-gwy module
Sara,
Yes you can do inter-vlan routing with the AGM module. Use the Gbit interface as the trunk and configure the subinterfaces. I can't send you any configs but I know it does work and have used it to do just this in the past.
Paul
Paul,
Thanks for the info, i tried that, create subinterface at gbit interface, encap dot1q. but it doesn't seems to work. do you need to set some backplane port as trunk also?
Sara
Sara, I would love to see your config so far. I have been un able to get inter vlan routing working so far. I do believe you need to set the backplane to trunk. Ie go into your cat 4006 and set slot/port to trunk. I have my back plane trunking, but I do not know how to get the AGM trunking.
The voice gateway is at mod 5
Router:
interface GigabitEthernet0/0
no ip address
interface GigabitEthernet0/0.1
description Virtual Routing Interface for User VLAN - user192_v
encapsulation dot1Q 100
ip address 10.178.192.254 255.255.255.0
interface GigabitEthernet0/0.2
description Virtual Routing Interface for Server VLAN - server223_v
encapsulation dot1Q 200
ip address 10.178.223.254 255.255.255.0
interface GigabitEthernet0/0.3
description Virtual Routing Interface for Voice VLAN - voice196_v
encapsulation dot1Q 300
ip address 10.178.196.254 255.255.255.0
Switch:
#module 5 : 1-port Voice Gateway
set trunk 5/1 nonegotiate dot1q 1-1005
sho ip route
Fragmentation Redirect Unreachable
enabled enabled enabled
The primary gateway: 10.178.223.254
ASTAR_C4006_C01> (enable) sho ver
WS-C4006 Software, Version NmpSW: 7.1(2)
Copyright (c) 1995-2002 by Cisco Systems, Inc.
NMP S/W compiled on Feb 7 2002, 16:53:43
GSP S/W compiled on Feb 07 2002, 15:24:55
System Bootstrap Version: 5.4(1)
Hardware Version: 3.2 Model: WS-C4006 Serial #: FOX0609005U
Mod Port Model Serial # Versions
1 2 WS-X4013 JAE061502JN Hw : 3.2
Gsp: 7.1(2.0)
Nmp: 7.1(2)
2 48 WS-X4148-RJ45V JAE061207GK Hw : 1.6
3 48 WS-X4148-RJ45V JAE061207PR Hw : 1.6
4 48 WS-X4148-RJ45V JAE061300FU Hw : 1.6
5 1 WS-X4604-GWY JAB0446050V Hw : 1.8
what is missing?
Sara
Sara,
I am using that module. We have the VWIC (MFT) installed and use for WAN connectivity. I had a bit of trouble getting it to work myself. You do know that the L3 part only supports (5 or 6 forgot) VLANS. I pruned all but the needed ones on the Dot1q trunk. Also What about the "native' VLAN at L3? Once I did all that everything seemed to work fine.
Are you using it for transcoding? Also there are some bugs in that version of IOS with Frame Relay. I upgraded to 12.2.7b and works fine.
Jim
Hi Jim,
I am Sara's colleague.
I have tried to clear the trunk on the gig port leaving behind just 5 VLANs. see config:
clear trunk 5/1 2-99,101-199,201-299,301-400,402-1005
set trunk 5/1 nonegotiate dot1q 1,100,200,300,401
but it doesn't seem to work. Do you have any sample configuration to share?
paul
Sara,
Here is a sample config that works.......Jim
set vlan 1 name default type ethernet mtu 1500 said 100001 state active
set vlan 2 name VLAN2 type ethernet mtu 1500 said 100002 state active
set vlan 3 name VLAN3 type ethernet mtu 1500 said 100003 state active
set vlan 4 name VLAN4 type ethernet mtu 1500 said 100004 state active
set vlan 5 name VLAN5 type ethernet mtu 1500 said 100005 state active
set vlan 10 name VLAN10 type ethernet mtu 1500 said 100010 state active
set vlan 50 name VLAN50 type ethernet mtu 1500 said 100050 state active
set vlan 1002 name fddi-default type fddi mtu 1500 said 101002 state active
set vlan 1004 name fddinet-default type fddinet mtu 1500 said 101004 state active stp ieee
set vlan 1005 name trnet-default type trbrf mtu 1500 said 101005 state active stp ibm
set vlan 1003 name token-ring-default type trcrf mtu 1500 said 101003 state active mode srb are
maxhop 0 stemaxhop 0 backupcrf off
#ip
set interface sc0 4 172.18.90.7/255.255.255.0 172.18.90.255
set interface sl0 down
set interface me1 down
set ip route 0.0.0.0/0.0.0.0 172.18.90.1
#syslog
set logging console disable
set logging level cops 2 default
#set boot command
set boot config-register 0x2
set boot system flash bootflash:cat4000.6-1-1.bin
#mls
set mls nde disable
#module 1 : 2-port 1000BaseX Supervisor
#module 2 : 18-port 1000BaseX Ethernet
set udld enable 2/7-10
set trunk 2/1 on dot1q 1-1005
set trunk 2/2 on dot1q 1-1005
set trunk 2/3 on dot1q 1-1005
set trunk 2/4 on dot1q 1-1005
set trunk 2/5 on dot1q 1-1005
set trunk 2/6 on dot1q 1-1005
set trunk 2/7 on dot1q 1-1005
set trunk 2/8 on dot1q 1-1005
set trunk 2/9 on dot1q 1-1005
set trunk 2/10 on dot1q 1-1005
#module 3 : 48-port Inline Power Module
set vlan 5 3/3-4
#module 4 : 1-port Voice Gateway
clear trunk 4/1 6-49,51-1005
set trunk 4/1 on dot1q 1-5,50
#module 5 empty
#module 6 empty
end
BCO-4006-L2 (enable)
LAYER PIECE
hostname BCO-4000-GWY
boot system flash flash:c4gwy-io3s-mz.122-7b.bin
no logging buffered
enable secret 5 $1$st0m$NQmDWhIPNOWlYR7tyw0Nf0
ip subnet-zero
ip wccp web-cache
ip audit notify log
ip audit po max-events 100
class-map match-all voice384
match access-group 166
class-map match-all voice192
policy-map voice192-policy
class voice192
priority 100
class class-default
fair-queue
policy-map voice384-policy
class voice384
priority 120
class class-default
fair-queue
controller T1 1/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
interface FastEthernet0/0
no ip address
speed 100
full-duplex
arp timeout 600
no ip address
no negotiation auto
encapsulation dot1Q 50
ip address 172.17.90.1 255.255.255.0
ip helper-address 10.90.10.111
ip address 192.168.90.1 255.255.255.0
interface GigabitEthernet0/0.4
encapsulation dot1Q 1 native
interface GigabitEthernet0/0.5
ip address 10.90.10.1 255.255.254.0
interface GigabitEthernet0/0.10
encapsulation dot1Q 4
ip address 172.18.90.1 255.255.255.0
interface Serial1/0:0
no ip address
encapsulation frame-relay
frame-relay traffic-shaping
frame-relay lmi-type cisco
frame-relay ip rtp header-compression passive
interface Serial1/0:0.2 point-to-point
description Frame Relay to BEH
ip address 172.16.70.2 255.255.255.252
frame-relay interface-dlci 23
class voip192
interface Serial1/0:0.3 point-to-point
description Frame Relay to GMS
ip address 172.16.10.2 255.255.255.252
frame-relay interface-dlci 21
class voip192
interface Serial1/0:0.4 point-to-point
description Frame Relay to WOP
ip address 172.16.60.2 255.255.255.252
frame-relay interface-dlci 20
class voip192
interface Serial1/0:0.5 point-to-point
description Frame Relay to RLA
ip address 172.16.20.2 255.255.255.252
frame-relay interface-dlci 18
class voip192
interface Serial1/0:0.6 point-to-point
description Frame Relay to GEO
ip address 172.16.40.2 255.255.255.252
frame-relay interface-dlci 19
class voip192
interface Serial1/0:0.7 point-to-point
description Frame Relay to MCK
ip address 172.16.50.2 255.255.255.252
frame-relay interface-dlci 24
class voip192
interface Serial1/0:0.8 point-to-point
description frame realy to GHS
ip address 172.16.30.2 255.255.255.252
frame-relay interface-dlci 17
class voip384
router eigrp 382
redistribute static
network 10.0.0.0
network 172.16.0.0
network 172.17.0.0
network 172.18.0.0
network 192.168.90.0
no auto-summary
no eigrp log-neighbor-changes
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 10.90.10.118
ip pim bidir-enable
map-class frame-relay voip192
no frame-relay adaptive-shaping
frame-relay cir 192000
frame-relay bc 1920
frame-relay be 0
frame-relay mincir 192000
service-policy output voice192-policy
frame-relay fragment 240
map-class frame-relay voip384
frame-relay cir 384000
frame-relay bc 3840
frame-relay be 0
frame-relay mincir 384000
service-policy output voice384-policy
frame-relay fragment 480
access-list 166 permit udp any any range 16384 32767 precedence critical
access-list 166 permit tcp any eq 1720 any
access-list 166 permit tcp any any eq 1720
Thanks Jim.
Sara
after configuring one of the subinterface to native vlan. it actually allow me to reach 3 of the 4 vlan i have configured despite making changes here and there
after a few reboot, all inter vlan routing cease to work..
attached is the config:
vtp
set vtp domain astarvlan
set vlan 2 name server223_v type ethernet mtu 1500 said 100002 state active
set vlan 3 name etpl204_v type ethernet mtu 1500 said 100003 state active
set vlan 4 name user192_v type ethernet mtu 1500 said 100004 state active
set vlan 50 name voice196_v type ethernet mtu 1500 said 100050 state active
--More-- set vlan 1002 name fddi-default type fddi mtu 1500 said 101002 state active
set vlan 1003 name token-ring-default type trcrf mtu 1500 said 101003 state active mode srb aremaxhop 7 stemaxhop 7 backupcrf off
#ip
set interface sc0 2 10.178.223.253/255.255.255.0 10.178.223.255
set ip route 0.0.0.0/0.0.0.0 10.178.223.254
#spantree
#backbonefast
set spantree backbonefast enable
#vlan
set spantree priority 0 2
set spantree priority 0 3
set spantree priority 0 4
set spantree priority 0 50
clear trunk 5/1 5-49,51-1005
set trunk 5/1 nonegotiate dot1q 1-4,50
System Bootstrap Version: 6.1(4)
Gsp: 7.1(2.0)
Nmp: 7.1(2)
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 65536K 36772K 28764K 16384K 7391K 8993K 480K 330K 150K
--More--
Uptime is 0 day, 16 hours, 13 minutes
ASTAR_C4006_C01> (enable) sho flash
-#- ED --type-- --crc--- -seek-- nlen -length- -----date/time------ name
1 .. ffffffff 6fb66023 45e468 20 4318184 --- -- ---- --:--:-- cat4000-k8.7-1-2.bin
2 .D ffffffff 1 45e4e8 29 0 May 13 2002 23:02:12 cat4000-promupgrade.6-1-4.bin
3 .. ffffffff f78babc 657a94 29 2069804 May 13 2002 23:07:52 cat4000-promupgrade.6-1-4.bin
9209196 bytes available (6388372 bytes used)
ASTAR_C4006_C01> (enable) session 5
Trying IntlgLineCard-5...
Connected to IntlgLineCard-5.
Escape character is '^]'.
ASTAR-4006-VGWY>en
ASTAR-4006-VGWY#sho run
Building configuration...
Current configuration : 1393 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname ASTAR-4006-VGWY
ip subnet-zero
ip audit notify log
call rsvp-sync
voicecard mode toll-by-pass
--More-- controller E1 1/0
channel-group 0 timeslots 1-31
controller E1 1/1
no ip address
duplex auto
speed auto
no ip address
no negotiation auto
--More-- ip address 10.178.192.254 255.255.255.0
description Virtual Routing Interface for ETPL VLAN - etpl204_v
ip address 10.178.204.254 255.255.255.0
no ip address
interface Serial1/1:0
no ip address
--More-- no ip http server
ip classless
ip pim bidir-enable
line con 0
line vty 0 4
login
end
ASTAR-4006-VGWY#
the problem is resolved by removing vlan 1. thanks everyone.
152
