Green
WS-X6624 FXS Problems with modems
Can anyone tell me if the WS-X6624 FXS card on 6509
CATs supports connections to modems.
My customer is complaining that although his connections get through he is constantly encountering errors in his data on his screens.
I have now seen this for myself and what comes on the screens is spurious characters with no real pattern in time or display. He is only connecting to async devices at 9600bps.
Any suggestions would be helpful.
Thank you.
Regards, Alex. Please rate useful posts.
1 ACCEPTED SOLUTION
Re: WS-X6624 FXS Problems with modems
I had the same problem and changed the levels on the ports to , I believe, -7 and +10.
Play with the levels and you should get it to work.
Green
Thank you for your help.
I have changed the type of connection on the card for modems to DAL and this
has cleared the the problem.
117
