WS-X6624 Not staying onhook
We're trying to use a 6624 port for overhead paging. The 6624 will not go back onhook. We can get on the paging system but it ends up playing dialtone over the speakers. Same thing with an analog phone.
IP Phone calls analog phone on a 6624 port. IP phone hangs up, theres a one second pause and then the port goes offhook. THe only way to clear the port is to reset the gateway or Module.
Using CM3.3(2c).
1 REPLY
Re: WS-X6624 Not staying onhook
Greetings Karl,
Please set the call restart timer for the 6624 port to 1234. This enables disconnect supervision (drop loop current after disconnect) on the 6624 port so it should meet your needs.
/Wes
110
