cnr
WSX6608 E1 blade and Nortel Meridian Connectivity
I am attempting to connect a WSX6608 E1 to a European Nortel Meridian switch. I am looking for a working config for the Meridian as our British Telecom Engineer has come up against a brick wall. We can get layers 1/2 up and running but the D channel log just shows the CCM sending restarts and the Meridian responding with Status. The CCM is set to network and Euro-ISDN but with the clock coming from the Meridian. Any hints would be welcomed. Thanks Chris
Re: WSX6608 E1 blade and Nortel Meridian Connectivity
Check the framing. Meridian does not defaul to CRC4.
We had a similar problem some time ago and we only got it working with CRC4. Use LD 73 in Meridian to change.
/ Rolf
as far as the 6608 blade is concerned, make sure you have "inhibit restarts at PRI initialization" checked, and then REBOOT your CCM after you make these Meridian changes. Taking Meridian out of the equation, TAC and I finally figured out this was a bug w/ 3.1(2c) and the WS6608 E1 blade that it keeps sending restarts and dropping the D channel (therefore disconnecting all calls) if you don't reboot the CM.
I'm am doing this in the US with a 6608 and a T1 to a Opt 61c if you're still having problems.
147
