XCCTSP error on Cisco 1760 with ISDN-2 BRI and MGCP
Hi all,
Somebody has seen this error message before?
Error- ISDN BRI backhaul XCCTSP created failed
This is happend when you will bind the ISDN-2 port to MGCP using "isdn bind-l3 ccm-manager service mgcp".
Can´t find anything on the forum..
Any suggestions?
TIA.
H2T
Re: XCCTSP error on Cisco 1760 with ISDN-2 BRI and MGCP
Kevin,
Sorry it is 1760-V. And yes it is supported because it is working on other three ports of VIC2-BRI module.
But the fourth port issue the error!
H2T
Right, just checked feature navigator and it is supported on the 17xx platforms. The technote is not terribly clear on that :-(
Is layer 2 up on the affected BRI?
If it is up then I would recommend opening a TAC case to determine if there are any know issues with backhauling multiple BRIs.
Kevin
Kevin,
Yes it is up but if you want to apply those command "isdn bind-l3...." you need to shut the port firs.
See below the log:
dedu-vgw#conf t
Enter configuration commands, one per line. End with CNTL/Z.
dedu-vgw(config)#int bri1/1
dedu-vgw(config-if)#isdn bind-l3 ccm-manager service mgcp
Please shutdown the interface before altering binding
dedu-vgw(config-if)#shut
Dec 30 15:31:37: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/1, TEI 0 changed to down
Dec 30 15:31:37: %LINK-5-CHANGED: Interface BRI1/1, changed state to administratively down
dedu-vgw(config-if)#no shut
Dec 30 15:31:46: %LINK-3-UPDOWN: Interface BRI1/1:1, changed state to down
Dec 30 15:31:46: %LINK-3-UPDOWN: Interface BRI1/1:2, changed state to down
Dec 30 15:31:46: BRI1/1 : Unexpected indication (4) in f3 code
Dec 30 15:31:46: %LINK-3-UPDOWN: Interface BRI1/1, changed state to up
Dec 30 15:31:46: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/1, TEI 0 changed to upend
dedu-vgw#
The weird thing is that this configuration has worked for more than two weeks and stops working suddently since this morning! At least the fourth port of it...
H2T
1194
