Community Member
XMedius Fax Express Edition problem
Hello!
I am trying to send fax the following way:
Xmedius Fax Express edition, by H.323 connected to 3845 with ISDN NT/TE vic card. I cannot send or receive fax trough this.
Here are configurations of important parts of 3845:
dial-peer voice 1 pots
max-conn 2
destination-pattern .T
direct-inward-dial
port 0/1/1
dial-peer voice 4 voip
destination-pattern 16171723
translate-outgoing calling 110
translate-outgoing called 4
session target ipv4:192.168.200.1¸5
dtmf-relay h245-signal
codec g711alaw
fax rate 14400
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
interface BRI0/1/1
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
voice-port 0/1/1
compand-type a-law
voice service pots
voice class h323 1
h225 timeout tcp establish 3
voice-card 0
no dspfarm
When I am trying to send fax, ISDN goes up, dials, and the connection is terminated. I am going directly from Fax server to VG, no CCM in between.
When I am trying to receive fax, it says that it is busy. Debug ISDN q931 is first paragraph in the attachment when I try to send fax, and when I try to receve fax, it looks like the second paragraph of the attachment.
Do you have any idea what is wrong with this?
Thank you in advance!
Best regards,
Darijo
1 REPLY
Bronze
Re: XMedius Fax Express Edition problem
I have had problems with Fax training up unless you have this command below.
1. enable
2. configure terminal
3. voice service voip
4. fax-relay sg3-to-g3
If you dont have the sg3 to g3 command available you need to update the IOS to one that supports it.
Also I am not familiar with the express edition but have had experience with the Xmedius full edition and have had to enable faststart which was a regedit.
452
