Community Member
XML for CCM 3.3.5
Is there XML applications for CCM 3.3.5 ?
I know they exist for CCM 4.X.X but what about 3.3.5 and where do you find them?
1 REPLY
Community Member
Re: XML for CCM 3.3.5
Do you meant to say SDK for CCM 3.3.5?
If you really meant applications for CCM 3.3.5, yes there are. Check out http://www.phonetop.com. PhoneTop Messenger allows one to push text and live audio (paging) to Cisco IP Phone groups. It also has Amber and emergency alerts (EAS) with CCM 3.3.5 support.
121
