Bronze
xmldirectory.asp and remote sites
HI
CM4.x with DCD- Is it possible to modify xmldirectory so it only searchs the respective sites. Say, you only have 30 users in remote site A and on a directory search you choose:
1. Main site
2. Remote site A
When a user choose A, he should only be able to search for users in A.
Currently I have 2 menuitem which as duplicate of each other but one saids Main and the other saids Remote so Users "think" they are searching 2 diff directories but it is the same directory.
1 REPLY
Re: xmldirectory.asp and remote sites
not really supported to change those files.
you better install the ip phone services sdk
and edit the direcory examples
124
