Cisco 4500x & Nexus 5548UP with Extender N2K-C2232TM-E (Unable to ping)
Tabish Mirza
Hi Folks,
We have following setup.
Two Cisco 4500x running VSS. All SVI are configured on it & it is running as a Layer 3.
Two N5K-C5548UP-FA single VPC. Both nexus 5000 connected to 4500x using two links from each nexus & going to CS 1 & 2.
Two C2232TM-E. each is connected to nexus 5000 using four febric links.
The problem is hosts connected to Nexus 2000 are unable to ping their gateway which is on Cisco 4500x.
I don't know what I am missing.
I am enclosing all configuration file for reference.
Please advise.
12 Replies 12
Steve Fuller
Level 9
Level 9
Hi Tabish,
I don't see the configuration files you mentioned. Can you attach again?
Core Switches Configuration Running as a VSS
HQDCCSW01#sh running-config
Building configuration...
Current configuration : 14121 bytes
! Last configuration change at 12:59:46 BAH Sun Feb 9 2014 by admin
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
service compress-config
service sequence-numbers
service counters max age 5
no service dhcp
hostname HQDCCSW01
boot-start-marker
boot system flash bootflash:cat4500e-universalk9.SPA.03.04.03.SG.151-2.SG3.bin
license boot level entservices
boot-end-marker
vrf definition mgmtVrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$7XzS$.tFbG1U2xPs8ht11VvTw./
username admin privilege 15 secret 5 $1$yIU1$bcq0.ES5HTowQzBTU03mo.
aaa new-model
aaa local authentication attempts max-fail 3
aaa session-id common
clock timezone BAH 3 0
switch virtual domain 10
switch mode virtual
mac-address use-virtual
udld enable
no ip source-route
no ip gratuitous-arps
ip icmp rate-limit unreachable 100
ip vrf Liin-vrf
no ip domain-lookup
ip domain-name HQ.com
no ip bootp server
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause unicast-flood
errdisable recovery cause arp-inspection
errdisable recovery interval 60
power redundancy-mode redundant
mac access-list extended VSL-BPDU
permit any 0180.c200.0000 0000.0000.0003
mac access-list extended VSL-CDP
permit any host 0100.0ccc.cccc
mac access-list extended VSL-DOT1x
permit any any 0x888E
mac access-list extended VSL-GARP
permit any host 0180.c200.0020
mac access-list extended VSL-LLDP
permit any host 0180.c200.000e
mac access-list extended VSL-MGMT
permit any host 00ff.d873.3de6
permit any host 00ff.7e1d.79e6
mac access-list extended VSL-SSTP
permit any host 0100.0ccc.cccd
spanning-tree mode rapid-pvst
spanning-tree loopguard default
spanning-tree portfast bpduguard default
spanning-tree vlan 1-2,5,8,51-53,100-101,200,254,300 priority 24576
redundancy
mode sso
vlan internal allocation policy ascending
ip ssh time-out 20
ip ssh authentication-retries 5
ip ssh version 2
class-map match-any VSL-MGMT-PACKETS
  match access-group name VSL-MGMT
class-map match-any VSL-DATA-PACKETS
  match any
class-map match-any VSL-L2-CONTROL-PACKETS
  match access-group name VSL-DOT1x
  match access-group name VSL-BPDU
  match access-group name VSL-CDP
  match access-group name VSL-LLDP
  match access-group name VSL-SSTP
  match access-group name VSL-GARP
class-map match-any VSL-L3-CONTROL-PACKETS
  match access-group name VSL-IPV4-ROUTING
  match access-group name VSL-BFD
  match access-group name VSL-DHCP-CLIENT-TO-SERVER
  match access-group name VSL-DHCP-SERVER-TO-CLIENT
  match access-group name VSL-DHCP-SERVER-TO-SERVER
  match access-group name VSL-IPV6-ROUTING
class-map match-any VSL-MULTIMEDIA-TRAFFIC
  match  dscp af41
  match  dscp af42
  match  dscp af43
  match  dscp af31
  match  dscp af32
  match  dscp af33
  match  dscp af21
  match  dscp af22
  match  dscp af23
class-map match-any VSL-VOICE-VIDEO-TRAFFIC
  match  dscp ef
  match  dscp cs4
  match  dscp cs5
class-map match-any VSL-SIGNALING-NETWORK-MGMT
  match  dscp cs2
  match  dscp cs3
  match  dscp cs6
  match  dscp cs7
policy-map VSL-Queuing-Policy
class VSL-MGMT-PACKETS
    bandwidth percent 5
class VSL-L2-CONTROL-PACKETS
    bandwidth percent 5
class VSL-L3-CONTROL-PACKETS
    bandwidth percent 5
class VSL-VOICE-VIDEO-TRAFFIC
    bandwidth percent 30
class VSL-SIGNALING-NETWORK-MGMT
    bandwidth percent 10
class VSL-MULTIMEDIA-TRAFFIC
    bandwidth percent 20
class VSL-DATA-PACKETS
class class-default
    bandwidth percent 5
interface Port-channel10
description *** VSS Connected to HQDCCSW02 ***
switchport
switchport mode trunk
switchport nonegotiate
switch virtual link 1
interface Port-channel11
description *** Uplink to Nexus 5000 DS ***
switchport
interface Port-channel12
description *** VSS Connected to HQDCCSW01 ***
switchport
switch virtual link 2
interface FastEthernet1
vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface TenGigabitEthernet1/1/1
description *** VSL Connected to HQDCCSW02 Port Te2/1/1 ***
no lldp transmit
no lldp receive
no cdp enable
channel-group 10 mode on
service-policy output VSL-Queuing-Policy
interface TenGigabitEthernet1/1/2
description *** VSL Connected to HQDCCSW02 Port Te2/1/2 ***
no lldp transmit
no lldp receive
no cdp enable
interface TenGigabitEthernet1/1/3
description *** Connected to HQDCDSW01 Port Mgt Keepalive Link ***
switchport access vlan 300
switchport mode access
interface TenGigabitEthernet1/1/4
interface TenGigabitEthernet1/1/5
interface TenGigabitEthernet1/1/6
interface TenGigabitEthernet1/1/7
interface TenGigabitEthernet1/1/8
interface TenGigabitEthernet1/1/9
interface TenGigabitEthernet1/1/10
interface TenGigabitEthernet1/1/11
interface TenGigabitEthernet1/1/12
interface TenGigabitEthernet1/1/13
interface TenGigabitEthernet1/1/14
interface TenGigabitEthernet1/1/15
description **** Connected to HQDCDSW01 Port Eth 1/27***
channel-group 11 mode active
interface TenGigabitEthernet1/1/16
description **** Connected to HQDCDSW02 Port Eth 1/27***
interface TenGigabitEthernet2/1/1
description *** VSL Connected to HQDCCSW01 Port Te1/1/1 ***
no lldp transmit
no lldp receive
no cdp enable
channel-group 12 mode on
interface TenGigabitEthernet2/1/2
description *** VSL Connected to HQDCCSW01 Port Te1/1/2 ***
no lldp transmit
no lldp receive
no cdp enable
interface TenGigabitEthernet2/1/3
description *** Connected to HQDCDSW02 Port Mgt Keepalive Link ***
interface TenGigabitEthernet2/1/4
interface TenGigabitEthernet2/1/5
interface TenGigabitEthernet2/1/6
interface TenGigabitEthernet2/1/7
interface TenGigabitEthernet2/1/8
interface TenGigabitEthernet2/1/9
interface TenGigabitEthernet2/1/10
interface TenGigabitEthernet2/1/11
interface TenGigabitEthernet2/1/12
interface TenGigabitEthernet2/1/13
interface TenGigabitEthernet2/1/14
interface TenGigabitEthernet2/1/15
description **** Connected to HQDCDSW01 Port Eth 1/28***
interface TenGigabitEthernet2/1/16
description **** Connected to HQDCDSW02 Port Eth 1/28***
interface Vlan1
description *** Servers_Old VLAN Interface ***
ip address 200.1.1.250 255.255.0.0
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan100
description *** New_Servers VLAN Interface ***
ip address 100.0.1.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan300
description *** Net_MGMT VLAN Interface ***
ip address 100.0.30.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip http server
no ip http secure-server
ip access-list standard ACL_RESTRICTED_VTY_SSH
remark permit any - till project completion
permit any
deny   any log
ip access-list extended VSL-BFD
permit udp any any eq 3784
ip access-list extended VSL-DHCP-CLIENT-TO-SERVER
permit udp any eq bootpc any eq bootps
ip access-list extended VSL-DHCP-SERVER-TO-CLIENT
permit udp any eq bootps any eq bootpc
ip access-list extended VSL-DHCP-SERVER-TO-SERVER
permit udp any eq bootps any eq bootps
ip access-list extended VSL-IPV4-ROUTING
permit ip any 224.0.0.0 0.0.0.255
ipv6 access-list VSL-IPV6-ROUTING
permit ipv6 any FF02::/124
line con 0
login authentication CONSOLE
stopbits 1
line vty 0 4
access-class ACL_RESTRICTED_VTY_SSH in
exec-timeout 30 0
login authentication VTY-SSH
transport input ssh
line vty 5 15
exec-timeout 30 0
transport input ssh
module provision switch 1
chassis-type 70 base-mac 24E9.B342.64D8
slot 1 slot-type 401 base-mac 24E9.B342.64D8
module provision switch 2
chassis-type 70 base-mac 885A.92CD.C5A8
slot 1 slot-type 401 base-mac 885A.92CD.C5A8
end
HQDCCSW01#sh cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
HQDCDSW02
                 Ten 2/1/16        170             S I C  N5K-C5548 Eth 1/28
HQDCDSW02
                 Ten 1/1/16        170             S I C  N5K-C5548 Eth 1/27
HQDCDSW02
                 Ten 2/1/3         176             S I C  N5K-C5548 mgmt0
HQDCDSW01
                 Ten 2/1/15        154             S I C  N5K-C5548 Eth 1/28
HQDCDSW01
                 Ten 1/1/15        154             S I C  N5K-C5548 Eth 1/27
HQDCDSW01
                 Ten 1/1/3         173             S I C  N5K-C5548 mgmt0
HQDCCSW01#sh interfaces trunk
Port        Mode             Encapsulation  Status        Native vlan
Po10        on               802.1q         trunking      1
Po11        on               802.1q         trunking      1
Po12        on               802.1q         trunking      1
Port        Vlans allowed on trunk
Po10        1-4094
Po11        1-4094
Po12        1-4094
Port        Vlans allowed and active in management domain
Po10        1-2,5,8,51-53,100,200,300
Po11        1-2,5,8,51-53,100,200,300
Po12        1-2,5,8,51-53,100,200,300
Port        Vlans in spanning tree forwarding state and not pruned
Po10        none
Po12        none.
Nexus 5548Up-FA Configuration
sh running-config
!Command: show running-config
!Time: Wed Mar  4 11:52:41 2009
version 7.0(0)N1(1)
hostname HQDCDSW02
no feature telnet
cfs eth distribute
feature udld
feature lacp
feature vpc
feature lldp
feature vtp
feature fex
ip domain-lookup
class-map type control-plane match-any copp-system-class-rpf-fail
fex 101
  pinning max-links 1
  description "HQDCSFW02"
snmp-server user admin network-admin auth md5 0xfa9292e2f91a27373c56829b4ddc2a67
priv 0xfa9292e2f91a27373c56829b4ddc2a67 localizedkey
rmon event 1 log trap public description FATAL(1) owner PMON@FATAL
rmon event 2 log trap public description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 log trap public description ERROR(3) owner PMON@ERROR
rmon event 4 log trap public description WARNING(4) owner PMON@WARNING
rmon event 5 log trap public description INFORMATION(5) owner PMON@INFO
spanning-tree port type edge bpduguard default
vrf context management
  ip route 0.0.0.0/0 100.0.30.1
vpc domain 1
  peer-switch
  peer-keepalive destination 100.0.30.250
  peer-gateway
  auto-recovery
  ip arp synchronize
interface port-channel1
  description *** Connected to HQDCDSW01 (E1/1,E1/2) ***
  spanning-tree port type network
  vpc peer-link
interface port-channel11
  description *** Connected to 4500 CS ***
  spanning-tree port type normal
  spanning-tree guard root
  vpc 11
interface port-channel101
  description *** UPLINK HQDCSFW02 ***
  switchport mode fex-fabric
  fex associate 101
interface Ethernet1/1
  description *** Connected to HQDCDSW01 (E1/1)
  channel-group 1 mode active
interface Ethernet1/2
  description *** Connected to HQDCDSW01 (E1/2)
interface Ethernet1/3
interface Ethernet1/4
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/10
interface Ethernet1/11
interface Ethernet1/12
interface Ethernet1/13
interface Ethernet1/14
interface Ethernet1/15
interface Ethernet1/16
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
interface Ethernet1/25
interface Ethernet1/26
interface Ethernet1/27
  description *** Connected to CS 4500 Port Te 1/1/16 ***
interface Ethernet1/28
  description *** Connected to CS 4500 Port Te 2/1/16 ***
interface Ethernet1/29
  description *** UPLINK HQDCSFW01 ***
  fex associate 101
  channel-group 101
interface Ethernet1/30
  fex associate 101
  channel-group 101
interface Ethernet1/31
  fex associate 101
  channel-group 101
interface Ethernet1/32
  fex associate 101
  channel-group 101
interface mgmt0
  vrf member management
  ip address 100.0.30.251/24
interface Ethernet101/1/1
  switchport access vlan 100
  vpc orphan-port suspend
interface Ethernet101/1/2
interface Ethernet101/1/3
interface Ethernet101/1/4
interface Ethernet101/1/5
interface Ethernet101/1/6
interface Ethernet101/1/7
interface Ethernet101/1/8
interface Ethernet101/1/9
interface Ethernet101/1/10
interface Ethernet101/1/11
interface Ethernet101/1/12
interface Ethernet101/1/13
interface Ethernet101/1/14
interface Ethernet101/1/15
interface Ethernet101/1/16
interface Ethernet101/1/17
interface Ethernet101/1/18
interface Ethernet101/1/19
interface Ethernet101/1/20
interface Ethernet101/1/21
interface Ethernet101/1/22
interface Ethernet101/1/23
interface Ethernet101/1/24
interface Ethernet101/1/25
interface Ethernet101/1/26
interface Ethernet101/1/27
interface Ethernet101/1/28
interface Ethernet101/1/29
interface Ethernet101/1/30
interface Ethernet101/1/31
interface Ethernet101/1/32
line console
line vty
boot kickstart bootflash:/n5000-uk9-kickstart.7.0.0.N1.1.bin
boot system bootflash:/n5000-uk9.7.0.0.N1.1.bin
Dear Steve,
I enclosed the configuration of CS 4500X VSS & Nexus 5000. Could you please have a look on it & let me know what I am missing. I am suspecting that Nexus 5000 is not working as a layer 2 switch that is why it is not forward traffic to Core Switch 4500x VSS. It suppose to work as a layer 2 switch.
Hi Tabish,
What does your spanning tree look like? Can you post a show spanning-tree vlan 100 from both the Nexus and the 4500 switches?
Hi Steve,
I don't know why did I put (spanning-tree guard root) on nexus 5000 portchannel which is being used to connect nexus 5000 to Core Switch 4500x VSS.
When I did show spanning interface port-channel 11 on Nexus 500 it shows below output.
HQDCDSW01# sh spanning-tree interface port-channel 11
Vlan             Role Sts Cost      Prio.Nbr Type
VLAN0100         Desg BKN*1         128.4106 (vPC) P2p *ROOT_Inc
Port 4106 (port-channel11, vPC) of VLAN0100 is broken  (Root Inconsistent)
   Port path cost 1, Port priority 128, Port Identifier 128.4106
   Designated root has priority 32868, address 0023.04ee.be01
   Designated bridge has priority 32868, address 002a.6a89.5f7c
   Designated port id is 128.4106, designated path cost 0
   Timers: message age 16, forward delay 0, hold 0
   Number of transitions to forwarding state: 2
   Link type is point-to-point by default
   Root guard is enabled
   BPDU: sent 4, received 1621
Hi Tabish,
That was what I'd noticed and hence thought spanning tree was your problem. Glad you resolved it.
Hi steve,
I removed this command ( spanning-tree guard root) on nexus 5000 port-channel. Do I need to configure this on Core Switch 4500x portchannel which is being used to connect with nexus 5000.
Core Switch 4500x
switchport
spanning-tree guard root ( or no need for this command)
Hi Tabish,
While root guard and the other spanning tree enhancements are of more use in an environment where STP is actively blocking links, they are still recommended in environments where technologies such as VSS are running.
In your environment you should configure spanning tree root guard on the Catalyst 4500 aggregation layer devices. As per the Spanning Tree Configuration Best Practices with VSS  section of the Cisco VSS design guide:
The root of the STP should always be the VSS. Use a statically-defined, hard-coded value for the spanning tree root so that no other switches in the network can claim the root for a given spanning tree domain. Use either Root Guard on a link of VSS-facing access-layer switch or enable it at access-layer switch user port (although the later does not prevent someone from replacing access-layer switch with another switch that can take over as root).
Hi Steve,
Now the hosts connected on nexus 2000 can ping their gateway which is on Core Switch 4500x as well as to each other different subnet but while doing testing I found that ping response time & TTL value is not stable. Response time is going up & down & TTL value is also high. There is no packet loss.
Please help & advise what could be the issue & what I can check.
Waiting for your prompt response.
Hi Tabish,
Can you paste an example of the ping results so we can see exactly what you mean in terms of the ping response time and TTL value variation?
If you could also provide an indication of where the ping source and destination are if it isn't obvious.
From windows machine which is connected on extender 2000 port to gateway which is on core switch 4500x mean SVI.
Hi Tabish,
Please paste the output of the ping from the client so we can see exactly what you're referring to by "ping response time & TTL value is not stable". From what you've provided I've no idea if you're referring to a change in response time between 1ms and 2ms, or between 1ms and 200ms.
That aside, the ping response time for pings to the switch itself is generally not a problem. It's well known that Cisco platforms do not prioritise ping response; they're a router after all. If you search through these forums you'll see many questions around this subject e.g., Latency High when ping to SVI on 3850 Stack & 4500X VSS. What about when you ping other clients connected to the switch? Is that response time stable or do you see the same variation?
The more intriguing point is where you have said that the TTL value is not stable. If the TTL shown in the ping response between the same source and destination is not constant, then this would indicate the number of router hops is changing between subsequent pings. If that's the case we should be able to see those different router hops using a repeated traceroute (or tracert on Windows). Can you run a tracert between the same source and destination a number of times so we can see what the difference is?
For both the ping and tracert response, please paste the output of the commands to the post so that we're not just guessing about what you're seeing.
