CISCO ACE - Port Forwarding + Load balancing
HI
I need to do the following scenario. I want to know that weather CISCO ACE is capable of doing it or not.
we have a special problem that we want to load balance the traffic over one server but on different TCP ports.
for example the traffic going to server with desPort:8080 , we want the Load balancer to redirect this traffic to the server but each time with a different port.(8080 or 8081 or 8082 or 8083).
in another word, load balance the traffic going to 10.1.1.1:8080 to these addresses: (10.1.1.1:8080 / 10.1.1.1:8081 / 10.1.1.1:8082 / 10.1.1.1:8083)
Is it possible to implement this kind of load balancing using CISCO ACE? and how can I do it?
thank you in advance
Hojabr
Silver
Just create a serverfarm with 4 rservers, the IP address will remain the same but the port will change in your association.
You might want to check out
You might want to check out this new product called ITD.
Simple and faster solution:
ITD provides :
  1. ASIC based multi-terabit/s L3/L4 load-balancing at line-rate
  2. No service module or external L3/L4 load-balancer needed. Every N7k port can be used as load-balancer.
  3. Redirect line-rate traffic to any devices, for example web cache engines, Web Accelerator Engines (WAE), video-caches, etc.
  4. Capability to create clusters of devices, for example, Firewalls, Intrusion Prevention System (IPS), or Web Application Firewall (WAF), Hadoop cluster
  5. IP-stickiness
  6. Resilient (like resilient ECMP)
  7. VIP based L4 load-balancing
  8. NAT (available for EFT/PoC). Allows non-DSR deployments.
  9. Weighted load-balancing
  10. Load-balances to large number of devices/servers
  11. ACL along with redirection and load balancing simultaneously.
  12. Bi-directional flow-coherency. Traffic from A-->B and B-->A goes to same node.
  13. Order of magnitude OPEX savings : reduction in configuration, and ease of deployment
  14. Order of magnitude CAPEX savings : Wiring, Power, Rackspace and Cost savings
  15. The servers/appliances don’t have to be directly connected to N7k
  16. Monitoring the health of servers/appliances.
  17. N + M redundancy.
  18. Automatic failure handling of servers/appliances.
  19. VRF support, vPC support, VDC support
  20. Supported on both Nexus 7000 and Nexus 7700 series.
  21. Supports both IPv4 and IPv6
  22. N5k / N6k support : coming soon
Blog
At a glance
ITD config guide
Email Query or feedback:ask-itd@external.cisco.com
1814
