DCNM Post-installation config: SSL set-up
<p>
I am a novice at this software.  I have two servers on different networks.  The software is installed and is answering its URL from the network but recently, I was required to change the hostnames and obtain new SSL certs.  The DCNM software is holding onto the older certs even though the new ones are installed to IIS.  I am looking for a solution to reconfiguring the SSL to use the new certs for HTTPS.  I got into the the Java Keytool thing and got REALLY turned around.  DCNM uses Tomcat or IIS?  Anyway, the old certs are still being used by the software.  That has to change.<br>
<br>
Thanx in advance<br>
<br>
Jeffrey D. Fisher
Windows Server Engineer
US Strategic Command/J646
Offutt AFB, NE USA
</p>
573
