Community Member
Discovered an annoying bug creating vPC FEX-to-Hosts
Hi there,
First of all, thanks a lot Lucien. You are the best!
Well, I´ll be brief:
I thought, that vPC from FEX-to-Hosts work as vPC between N5K-to-FEX does. You create the Port-channel, and you move it to vPC manually.
But it´s not, from FEX-to-Host you gotta configure just the Port-channel, and then, that Port-channel is internally assigned to a vPC. Easier. That´s fine.
PROBLEM: When I removed the vpc commands underneath of the FEX-to-Host Portchannels, I realized that although the internal vPC look healthy now (up and successfull), I can still see old vPC after executing SHOW VPC:
1004   Po1004      up     Not         Consistency Check Not      -
                          Applicable  Performed
263147 Po1004      up     success     success                    1-2,7-8,10-
        11,46,98-10
        0,150,199,2
        42,245-246,
        251,254-....
If I create new Port-channels, just internal vPC show up.
I believe this is a bug, and there is no easy way to clear up the old/utilized vPC. I tried to #clear vPC and so forth, but no luck.
what can i tell to my customer? any chance to have this fixed?
NX-OS are updated to the last version (1month ago)
kickstart image file is: bootflash:///n5000-uk9-kickstart.5.1.3.N2.1.bin
  kickstart compile time:  3/20/2012 0:00:00 [03/20/2012 08:51:29]
kickstart: version 5.1(3)N2(1)
  system:    version 5.1(3)N2(1)
Thanks a lot everyone,
Hello Josu
I can test this in my lab. So let me know if I understand the sequence of operations correct.
1)You created interface Po1004 and then added vpc 1004 under it on both Nexus 5500s
interface Port-channel1004
vpc 1004
2)You tried adding "channel-group 1004" to A/A FEX interfaces but it failed.
3)You removed vPC keyword under "interface Port-channel1004" but show vpc command still shows vPC 1004
-Prashanth
Community Member
Thanks a lot prkrishn,
1.- Find attached a network diagram
2.- Sequence is like this:
You create a a vPC from two different FEX to a Host like this:
                                interface Ethernet101/1/4
          switchport mode trunk
          channel-group 1004
                                interface Ethernet102/1/4
          channel-group 1004
Then you assign a vpc to the channel-group
                                interface po1004
          vpc 1004           <-- this is wrong, triggering the problem. I shouldn’t have typed that.
If I do a SHOW VPC, I can see both vPC id: 1004 and Internal vpc, for instance, 123324, pointing at the Po1004. Only the internal one is SUCCESS.
Now, even though I clear up “vpc 1004”, both vPC id still appear when SHOW VPC
If I create a brand new Port-Channel, works fine. Just internal vPC is created.
Cheers!
You can also ring me: +34 634 645 001
Hi Josu
I tried from config t and conf sync as well and cannot recreate the problem. If you can, let me know the steps or we can set up a webex.
-Prashanth
727
