Hi All
Need a help in the below attached jpg for the switching .
Sudharsan.R
91+8220088865
1 REPLY
Hi All
Hi Sudharsan
First you need to check config on 2960 switch whether access vlans are set correclty.
Then check config on n5k.
links on sw 13 - g1/21 and g1/23 can be configured as one portchannel, 22 and 24 as the second and 2 vpc portchanels from n5k side.
Then reenable shutted links between sw 13 and nexuses. If loop will occur - stp will block it, if not - check which link causes loop.
HTH,
Alex
697
