Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
LACP ports on N5K to N7Ks went into suspend mode after upgrading code from 5.0.3 to 5.1.3
When we try to upgrade the code from 5.0.3 to 5.1.3, all links from N5K to N7K and vice versa went into suspended mode. Those ports are configured as LACP.
We are using following interfaces Eth 4/17, 5/17 on line card model N7K-M132XP-12 going to N5K1 layer2 portchannel2 (eth1/30 and Eth 1/31) . Interface 4/18, 5/18 on line card model N7K-M132XP-12 going to N5K2 layer2 portchannel2 VPC (eth 2/13 and eth 2/15). THis is on One N7K1 switch and the same way configured on N7K2 gateway. N5K1 and N5K are formed as VPC pair. I did almost 20 pair of switch upgrade in LACP but did not had any such problem.
Eth4/17       Q08-sw1-et connected trunk     full    10G     10Gbase-SR
Eth4/18       Q08-sw2-et connected trunk     full    10G     10Gbase-SR
Eth4/19       --                 disabled  routed    auto    auto    10Gbase-SR
Eth4/20       --                 disabled  routed    auto    auto    10Gbase-SR
Eth4/21       --                 disabled  routed    auto    auto    10Gbase-SR
Eth4/22       --                 disabled  routed    auto    auto    10Gbase-SR
Eth4/23       --                 disabled  routed    auto    auto    10Gbase-SR
Eth4/24       --                 disabled  routed    auto    auto    10Gbase-SR
Eth5/17       Q08-sw1-et connected trunk     full    10G     10Gbase-SR
Eth5/18       Q08-sw2-et connected trunk     full    10G     10Gbase-SR
Eth5/19       --                 disabled  routed    full    auto    10Gbase-SR
Eth5/20       --                 disabled  routed    full    auto    10Gbase-SR
Eth5/21       --                 sfpAbsent routed    full    auto    --
Eth5/22       --                 sfpAbsent routed    full    auto    --
Eth5/23       --                 sfpAbsent routed    full    auto    --
Eth5/24       --                 sfpAbsent routed    full    auto    --
interface port-channel17
  description Q07-sw1/sw2_e2/15
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 101-106,108-109,111-119,130,161
  spanning-tree port type normal
  spanning-tree guard root
  vpc 17
interface eth4/17-18, eth5/17-18
  switchport
  vpc 17
On N5K1/2 switches: Here are the configs:
interface port-channel2
  description VPC N7K1/N7K2
  vpc2
interface Ethernet1/30-31, Eth2/14-15
  description N7K-gw1/gw2
  channel-group 2 mode active
96
