You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
Nexus 1010 and Management
it is the first time that i install and configure a Nexus 1010.
After unpackaging, i have upgrade the BIOS, CMC and Firmware of the nexus 1010 (like a classical C-serie server)
The CIMC 's @IP is 10.10.0.100 ; I have connected the 10/100 Ethernet CIMC management port to my OOB  network where we have all OOB interfaces from Nx7k and Nx5k.
Now i would want configure the Nx1010 in the topology "uplink type 3".
port 1 and 2 : mangement Vlan
port 3 to 6 : Control/packt Vlan and Data Vlan.
In the setup wizard, we have to configure the int Mgmt0 of Nx 1010.
In which network must be the Mgmt0 ; i am confused and mix up :
- CIMC mgmt from the C-series server
- mgmt0 int from nexus 1010 : by which physical interface goes throught this traffic : via "10/100 Ethernet CIMC management port" or via "Management vlan" ???
- Vlan management : this Vlan will allow to manager the VSB VSM-1 et VSM-2....
The Vlan management must not be the OOB network, must it ?
It is not clear for my mind ; i mix up all this mgmt
please help me !!!
many thank in advance.
NB : All the devices in our DC (Nx5k and Nx5K/Nx2K) have two management interface :
1 - OOB management via the pysical OOB port
2 - Inb management via a dedicated Vlan ; each device have 1 @IP in this Vlan (even the L2 Nx7k (without M1 card) via the cli "management")
How could i have the these mgmt for Nexus 1010 / CIMC / VSM ???
Last question : in order to upgrade the nx 1010, then download the nexus-1000v*.iso to bootflash:repository, which network/mgmt i have to used ???
  • Other Data Center Subjects
1 REPLY
Hi Delahais, could you resolve your concern? .. I have the same doubt
818
