Nexus 5000 rebooted after receiving %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by on ppm.3523
We have two Nexus 5000 in HA configuration that use a switch port profile to share configuration changes.
Earlier this morning the secondary switch rebooted (this has happened before).
Just prior to the reboot the syslog server received the following command.
Dec 18 07:08:32 10.91.254.62 : 2013 Dec 18 07:08:32 AEST: %ASCII-CFG-6-INFORMATION: Reading ACFG Runtime information
Dec 18 07:08:33 10.91.254.62 : 2013 Dec 18 07:08:33 AEST: %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by  on ppm.3523
Dec 18 07:08:33 10.91.254.62 : 2013 Dec 18 07:08:33 AEST: %ASCII-CFG-6-INFORMATION: Reading ACFG Runtime information
Any help with diagnosing this issue will be appreciated
Version information below.
Software
  BIOS:      version 3.5.0
  loader:    version N/A
  kickstart: version 5.1(3)N2(1)
  system:    version 5.1(3)N2(1)
  power-seq: Module 1: version v1.0
             Module 3: version v2.0
  uC:        version v1.2.0.1
  SFP uC:    Module 1: v1.0.0.0
  BIOS compile time:       02/03/2011
  kickstart image file is: bootflash:///n5000-uk9-kickstart.5.1.3.N2.1.bin
  kickstart compile time:  3/20/2012 0:00:00 [03/20/2012 18:51:29]
  system image file is:    bootflash:///n5000-uk9.5.1.3.N2.1.bin
  system compile time:     3/20/2012 0:00:00 [03/20/2012 20:00:58]
Hardware
  cisco Nexus5548 Chassis ("O2 32X10GE/Modular Universal Platform Supervisor")
  Intel(R) Xeon(R) CPU         with 8263864 kB of memory.
  Processor Board ID FOC15504PN3
  Device name: AALN5KPDC03
  bootflash:    2007040 kB
Kernel uptime is 0 day(s), 3 hour(s), 1 minute(s), 48 second(s)
Last reset at 429902 usecs after  Wed Dec 18 07:03:10 2013
  Reason: Kernel Panic
  System version: 5.1(3)N2(1)
  Service:
plugin
  Core Plugin, Ethernet Plugin
  • Other Data Center Subjects
1 REPLY
Re: Nexus 5000 rebooted after receiving %VSHD-5-VSHD_SYSLOG_CONF
In case a unexpected reboot with a kernel panic reason I recommend to you to open a case with Cisco TAC team.
Probably is related a bug CSCua53582.
Richard
1250
