Nexus 5020 facing issue
We are facing issue with Nexus device partcode:N5K-C5020P-B-S as description below,
Issue: Nexus 5k switches have multiple enteries for Management IP(Same IP multiple times) in the startup configuration, whereas in Running Configuration it shows only one entry for Management IP.
The NX-OS used is: boot kickstart bootflash:/n5000-uk9-kickstart.4.2.1.N2.1.bin boot system bootflash:/n5000-uk9.4.2.1.N2.1.bin
Attaching here document showing running & startup config.
Confirm us if there is some bug imapact
Ashutosh
1 ACCEPTED SOLUTION
It seems you are hitting CSCth73191.
Fixed-In Fixed-in
5.1(3)N
Symptoms
See duplicate lines in starting config for mgmt 0 interface.
Conditions
none
Workaround
None.  This is only a cosmetic bug.
Can any one suggest me on the above query??
This is Nexus OS issue having any BUG impact or some other issue??
Already attached file showing the issue........
Ashutosh
I have not seen this yet, to be honest. Are you able to reach the mgmt0 by that IP? Also what happens if you remove the configuration and reply it? I'll do some more research and see if I can find a particular bug that relates to this, but it seems
cosmetic unless you're experencing problems reaching the IP.
Fixed-In Fixed-in
5.1(3)N
Symptoms
Conditions
none
Workaround
Hello Colby,
Thanks for providing this BUG information as I was unable to through Cisco BUG toolkit.
Suggest me if we have to go for Nexus OS upgrade to resolve this duplicate line's issue with startup configuration and share us the BUG free Nexus OS for further upgrade.
Ashutosh
This if fixed in 5.1(3) or higher. I would look over the release notes for any open and closed caveats
http://www.cisco.com/en/US/products/ps9670/prod_release_notes_list.html
1002
