Community Member
Nexus 5596P
Hi, we have Nexus 5596p and we can't create any ip prefix-lists for redistributing routes, although in the NX-OS configuration guide says that it is possible. Can you please give me a any hint ?
Version of NX-OS on 5596 UP:
kickstart image file is: bootflash:///n5000-uk9-kickstart.5.1.3.N1.1.bin
                system image file is:    bootflash:///n5000-uk9.5.1.3.N1.1.bin
DC_Strumica_SW1(config)# sh feature
Feature Name          Instance  State
Flexlink              1         disabled
amt                   1         disabled
bgp                   1         disabled
cts                   1         disabled
dhcp                  1         disabled
dot1x                 1         disabled
eigrp                 1         enabled
eigrp                 2         enabled
eigrp                 3         enabled (not-running)
eigrp                 4         enabled (not-running)
eth_port_sec          1         disabled
fcoe                  1         disabled
fcoe-npv              1         disabled
fex                   1         enabled
glbp                  1         disabled
hsrp_engine           1         enabled
http-server           1         disabled
interface-vlan        1         enabled
lacp                  1         enabled
ldap                  1         disabled
lldp                  1         enabled
msdp                  1         disabled
ospf                  1         disabled
ospf                  2         disabled
ospf                  3         disabled
ospf                  4         disabled
pim                   1         disabled
poe                   1         disabled
private-vlan          1         disabled
privilege             1         disabled
ptp                   1         disabled
rip                   1         disabled
rip                   2         disabled
rip                   3         disabled
rip                   4         disabled
sshServer             1         enabled
tacacs                1         enabled
telnetServer          1         disabled
udld                  1         enabled
vem                   1         disabled
vmfex                 1         disabled
vpc                   1         enabled
vrrp                  1         disabled
vtp                   1         disabled
DC_Strumica_SW1(config)# ip ?
  access-list        Configure access list
  adjmgr             AM information
  arp                Configure ARP parameters
  as-path            BGP autonomous system path filter
  auto-discard       Auto 0.0.0.0/0 discard route
  community-list     Add a community list entry
  dns                Configure dns client
  domain-list        Add additional domain names
  domain-lookup      Enable/Disable DNS
  domain-name        Specify default domain name
  eigrp              EIGRP clear commands
  extcommunity-list  Add a extcommunity list entry
  host               Add an entry to the ip hostname table
  igmp               IGMP configuration commands
  igmp               IGMP global configuration commands
  internal           Commands for internal use
  load-sharing       ECMP load-sharing
  mfwd               Configures Global IP Multicast Forwarding
  mroute             Configure multicast RPF static route
  name-server        Specify nameserver address
  radius             Radius server
  route              Route information
  routing            Routing information
  source-route       IP source routing option
  tacacs             Tacacs server
  tcp                Global TCP parameters
  telnet             Configure telnet
  tftp               Configure TFTP client
Re: Nexus 5596P
There is a new bug opened against this. You will have to fall back to 5.0(3)N2(2b) to configure prefix-list.
I cannot share the bug ID right now, it is still internal.
jerry
Nexus 5596P
1874
