08-03-2012 06:49 AM - edited 03-01-2019 07:09 AM
I am unable to get a firm answer for this and have no luxury of laying my hands on a 7K to test. Here is the deal...
I know and understand the ISSU process on a dual supervisor situation on N7K. I also understand the ISSU on N5K, which has a single supervisor. I believe in N5K, it is possible to upgrade NX-OS without disrupting the data plane operations, even though it only has a single supervisor.
But my question is, is real ISSU possible on N7K with a single supervisor module. From the documents I have seen on Cisco website, it seems not possilbe. As per the documennt, we need to use the "reload" command instead of "install all" command if N7K has only 1 Sup. Is that right?
Appreciate your help.
Mohan
08-03-2012 05:25 PM
Like the CCO doc said, it is not possible to do ISSU on a N7K with single SUP.
N5K has very strict requirement to perform ISSU (cannot be STP root, LACP fast hello is not supported, etc.), this include the control plane reset needs to come back up before 90 second, which is not possible with the N7K supervisor.
Yes, the doc is correct, you need to do a "reload" instead of "install all".
HTH,
jerry
08-03-2012 11:43 PM
Hey Jerry!
Where have you been hiding?
08-04-2012 09:21 AM
Hi Leo,
I move to the data center team and busy with all my customers (need to take care 3x more customers than before).
jerry
08-04-2012 04:46 PM
Hope is well Jerry.
08-04-2012 07:15 PM
Thanks Leo. Same to you.
jerry
