Nexus 7k non- default VDC and vPC keepalive
I have a question. I have a pair of nexus 7k's running in production. They are configured on the default VDC and using the mgmt0 interface as the vPC keepalive link. I created a new VDC labeled TEST and wanted to setup vPC and fabricpath on my new VDC. But should I use the test VDC mgmt0 for my keepalives or will that break my production setup? Can I set it up over an SVI ? Any advice would be appreciated!
Timmyz
  • Other Data Center Subjects
1 ACCEPTED SOLUTION
You can re-use the mgmt0 interface for vPC keep alive in the new VDC.
This interface can have a unique IP address in each VDC.
See below:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_0/nx-os/fundamentals/configuration/guide2/fun_5sys_mgmt.html
Don't forget to rate all helpful posts
See below:
Thats it!! thank you very much. I am up and working.
710
