Nexus 7k vPC to Catalyst 3750
All,
I am having trouble getting a port-channel to come up.  I have two Nexus 7ks connected to one Catalyst 3750.  Please lend me some assistance.  Here are the relavant configs for each:
Nexus7k-1# sh ru int po48
interface port-channel48
description uplink to Catalyst3750
switchport
switchport mode trunk
switchport trunk native vlan 666
switchport trunk allowed vlan 2050
vpc 48
Nexus7k-2# sh ru int po48
switchport
vpc 48
Nexus7k-1# sh ru int e1/2
interface Ethernet1/2
switchport
channel-group 48 mode active
no shutdown
Nexus7k-2# sh ru int e1/2
switchport
no shutdown
PHCSW11-37673-SC44#sh ru int po48
! interface Port-channel48
description Uplink to EBU
switchport nonegotiate
Catalyst3750#sh ru int t1/1/1
! interface TenGigabitEthernet1/1/1
description to Nexus7k-1
channel-protocol lacp
end
Catalyst3750#sh ru int t1/1/2
! interface TenGigabitEthernet1/1/2
description Nexus7k-2
Everyone's tags (4)
Re: Nexus 7k vPC to Catalyst 3750
Nexus7k-1# sh vpc 48 vPC status ---------------------------------------------------------------------- id  Port  Status Consistency Reason                    Active vlans --  ----  ------ ----------- ------                    ------------ 48  Po48  down*  success    success                    - Nexus7k-1# show vpc consistency-parameters vpc 48     Legend:         Type 1 : vPC will be suspended in case of mismatch Name                        Type  Local Value            Peer Value -------------              ----  ---------------------- ----------------------- STP Port Type              1    Default                Default STP Port Guard              1    None                  None STP MST Simulate PVST      1    Default                Default Allowed VLANs              -    2050                  2050 Local suspended VLANs      -    -                      - Nexus7k-2# sho vpc 48 vPC status ---------------------------------------------------------------------- id  Port  Status Consistency Reason                    Active vlans --  ----  ------ ----------- ------                    ------------ 48  Po48  down*  Not        Consistency Check Not      -                   Applicable  Performed Nexus7k-2# show vpc consistency-parameters vpc 48     Legend:         Type 1 : vPC will be suspended in case of mismatch Name                        Type  Local Value            Peer Value -------------              ----  ---------------------- ----------------------- STP Port Type              1    Default                Default STP Port Guard              1    None                  None STP MST Simulate PVST      1    Default                Default Allowed VLANs              -    2050                  2050 Local suspended VLANs      -    -                      -
That's the same command output as posted the post earlier except cleaner.  Cannot stand how text copies into the editor, so I pasted it into notepad and made it an image to read easier.  Can anyone help me as to why the port-channel will not come up?  Do you need any more information?
Matt
Hi Matt
Can you please show:
sh vpc
sh port-cha summ | grep 48
sh int eth 1/2
sh int po48
from both n7k.
Alex
See attached
Hi Matthew
Andras is right. From the output - both physical interfaces suspended and port-chanel is down due to abscence of operational members.
Usually links are suspended due to inconsistency of configuration on LACP peers.
If you check the log on n7k (show log log) and catalyst (sh log) you should see the reason why the links are suspended.
But most likely it's due to native vlan mismatch.
Alex
You didn't set native VLAN on the 3750.
Mat,
I will suggest to check 2 things to narrow it down.
1.Remove the ports from port channel and confirm they are coming up/up as trunk ports to narrow down issue with LACP .
2.Is native vlan 666  up ? i dont see that on the VPC peer link if that is up i should see that,this could be due to the fact that you have L2  inconsistency (Type-2 inconsistency reason       : VTP type-2 configuration incompatible ) fix this as well.
Vishwa..
8148
