Nexus peer link down
Dears ,
I'm configuring the fabric path on F2 module between two Nexus 7k and these are not coming up below is the config what i did on both nexus 7K with version 6.1
N7K1
vlan ,2,3
  mode fabricpath
fabricpath switch-id 11
vpc domain 1
  fabricpath switch-id 10
interface port-channel1
  switchport
  switchport mode fabricpath
  vpc peer-link
int e1/47
switchport
int e1/48
switchport
N7K2:
vlan ,2,3
  mode fabricpath
vpc domain 1
  switchport
  vpc peer-link
int e1/47
switchport
int e1/48
switchport
N7K1: sh interface po1
port-channel1 is down (No operational members)
admin state is up,
  Hardware: Port-Channel, address: 0000.0000.0000 (bia 0000.0000.0000)
  Description: **** Connected to Nexus 7K Core_1 ****
  MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec
  Encapsulation ARPA, medium is p2p
  Port mode is FabricPath
  auto-duplex, auto-speed
  Input flow-control is off, output flow-control is off
  Auto-mdix is turned off
  Switchport monitor is off
  EtherType is 0x8100
  No members
  0 interface resets
  0 seconds input rate 0 bits/sec, 0 packets/sec
  0 seconds output rate 0 bits/sec, 0 packets/sec
  Load-Interval #2: 0 seconds
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
sh vpc brief
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 1
vPC+ switch id                    : 10
Peer status                       : peer link is down
vPC keep-alive status             : peer is alive
vPC fabricpath status             : peer not found
Configuration consistency status  : failed
Per-vlan consistency status       : success
Configuration inconsistency reason: Consistency Check Not Performed
Type-2 inconsistency reason       : Consistency Check Not Performed
vPC role                          : none established
Number of vPCs configured         : 0
Peer Gateway                      : Disabled
Dual-active excluded VLANs        : 2,3
Graceful Consistency Check        : Disabled (due to peer configuration)
Auto-recovery status              : Enabled (timeout = 240 seconds)
Fabricpath load balancing         : Disabled
Port Channel Limit                : limit to 244
vPC Peer-link status
id   Port   Status Active vlans
1    Po1    down   -
sh vpc consistency-parameters global
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
STP Mode                    1     Rapid-PVST             -
STP Disabled                1     None                   -
STP MST Region Name         1     ""                     -
STP MST Region Revision     1     0                      -
STP MST Region Instance to  1                            -
VLAN Mapping
STP Loopguard               1     Disabled               -
STP Bridge Assurance        1     Enabled                -
STP Port Type, Edge         1     Normal, Disabled,      -
BPDUFilter, Edge BPDUGuard        Disabled
STP MST Simulate PVST       1     Enabled                -
Allowed VLANs               -     -                      -
Local suspended VLANs       -     -                      -
switch-OMANTEL-Core_2#
  • Other Data Center Subjects
anybody can help me to solve the issue.
Hello Jack,
The fabricpath switch-id must be different, only the sub-switch-id must be the same.
fabricpath switch-id 11 (Must be different in the other peer)
vpc domain 1
  fabricpath switch-id 10 (Must be the same)
Switch-id
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/fabricpath/configuration/guide/fp_switching.html#wp1791414
Sub-switch-id (vPC+)
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/fabricpath/configuration/guide/fp_interfaces.html#wp1674575
Be aware by VDC requirement as well.
Richard
The response from Barbosa is correct.
Take a look at the Quick Start Guide :: FabricPath; you can download the ppt file at https://supportforums.cisco.com/docs/DOC-34758
Look at and reference slide 14 & 17 - 19
I hope this helps you with your design.  You can also reference the Quick Start Guide :: vPC as well; this will give you the foundation when you run vPC+ in your FP environment.
https://supportforums.cisco.com/community/netpro/data-center/others?view=documents
2015
