nexus switches - is the commands different than IOS
Hi all
I know that the nexus switches use NEXOS ios
do they use different commands to do things or is it the same as configuring IOS?
cheers
Carl
Hi Carl,
Most configuration commands in NX-OS are parrallel with IOS.  There was a big push to make the two operating systems feel similar as most people would have a mix of devies.
So in general NX-OS has same config setup...enable, global config, interface config structure.  Most commands are very similar as well.
Re: nexus switches - is the commands different than IOS
Here is a great link detailing a comparison of the two.
http://docwiki.cisco.com/wiki/Cisco_NX-OS/IOS_Configuration_Fundamentals_Comparison
Hope this helps.
Carl
Many commands are very similar to IOS, but a lot of them doesn't have equivalents in nx-os.
But you also need to take into consideration that many commands which have heir equivalents might have different behavior since iOS and nx-os have completely different architecture, and nexus and routers are also technically different.
1526
