11-24-2010 04:27 AM - edited 03-01-2019 06:53 AM
Hi all,
In a presentation on the web it says that :
Solved! Go to Solution.
11-30-2010 11:19 AM
Greets,
That is a really well thought out question, took me a couple of reads to realise what you were asking.
Both switches generate BPDUs with the same Priority/MAC for vPC interfaces, however the behaviour is not the same on non-vPC interfaces. The reason is pretty simple, the edge switch WILL block one of the two links, if it has to come down to Port ID as the descriminator it will happily do so. So if both switches send identical BPDUs, the one with the lowest port ID will always end up being the root, while the second port is blocking. If this behaviour is replicated for all VLANs, you have one link taking all traffic from the edge switch.
To avoid this we have a concept of "psuedo information" that means on vPC interfaces we advertise the same priority, however on non-vPC interfaces we can advertise two different priorities (on a per instance/VLAN basis). So you can have the link to SW1 being the root for VLAN X, while SW2 the root for VLAN Y. So while peer-switch provides additional flexibility to load balance per STP instance over the two links, it will not really help you in this failure scenario.
The problem with having your host dual homed but using standalone links, is from a logical perspective it is still an orphan port (as we will always block on one of the two ports). Although I can't see any situation where you would have a dual homed host, but it not be in a vPC, so it is kind of a corner case.
Chris
11-30-2010 11:19 AM
Greets,
Chris
11-30-2010 10:22 PM
Hi Cris,
First of all, appreciate your response. Well, when I had that question I hadnt read all the docs about the failure situation. Then I realized that, when peer link goes down, vPC operational secondary switch will shuts is vPC member ports (not the regular STP ports) and also the SVIs for those vPC VLANs.
thanks a lot .
Cheers.
