02-16-2014 07:13 PM - last edited on 03-25-2019 01:29 PM by ciscomoderator
We would like to test OTV in the lab but we only have one N7K and a ASR1K. Wondering if the N7K can build OTV with ASR1K?
Thanks. Leo
Solved! Go to Solution.
02-17-2014 09:14 AM
Hello there,
I did the same question same time ago here:
https://supportforums.cisco.com/thread/2233262
That's the answer:
"Mixing the two types of devices is not supported at this time when the devices will be placed within the same site.
However, using Cisco Nexus 7000s in one site and Cisco ASR 1000s at another site for OTV is fully supported.
For this scenario, please keep the separate scalability numbers in mind for the two different devices, because you will have to account for the lowest common denominator."
Richard
02-17-2014 09:14 AM
Hello there,
That's the answer:
Richard
02-17-2014 02:10 PM
Good on you Richard, thanks for your reply. Did you have a chance to test it?
Regards, Leo
