10-08-2014 10:27 PM - edited 03-01-2019 07:40 AM
Friend i try to join two VDC by VPC but can not , according to the error there is not comunication beteween two VDC. I check the configuration and i think is good. maybe the problem could be the module N7K-F248XP-25E is possible to form vpc in this module ?
CORE6
vrf context keepalive
description ++ to vPC keepalive link ++
vrf context management
ip route 0.0.0.0/0 10.0.10.1
vpc domain 1
peer-keepalive destination 192.168.1.1 source 192.168.1.2 vrf keepalive
peer-gateway
interface Vlan1
no ip redirects
interface Ethernet4/37
vrf member keepalive
ip address 192.168.1.2/24
no shutdown
NK7-02-CORE6# show vpc peer-keepalive
vPC keep-alive status : Suspended (Destination IP not reachable)
--Send status : Success
--Last send at : 2014.10.09 08:20:09 454 ms
--Sent on interface : Eth4/37
--Receive status : Failed
--Last update from peer : (554662) seconds, (510) msec
vPC Keep-alive parameters
--Destination : 192.168.1.1
--Keepalive interval : 1000 msec
--Keepalive timeout : 5 seconds
--Keepalive hold timeout : 3 seconds
--Keepalive vrf : keepalive
--Keepalive udp port : 3200
--Keepalive tos : 192
Mod Ports Module-Type Model Status
1 0 Supervisor Module-2 N7K-SUP2E active *
2 0 Supervisor Module-2 N7K-SUP2E ha-standby
3 24 10 Gbps Ethernet Module N7K-M224XP-23L ok
4 48 1/10 Gbps Ethernet Module N7K-F248XP-25E ok
CORE5
vpc domain 1
peer-keepalive destination 192.168.1.2 source 192.168.1.1 vrf keepalive
peer-gateway
interface Vlan1
no ip redirects
ip address 192.168.1.1/24
no shutdown
N7K-01-CORE5# show vpc peer-keepalive
--Last send at : 2014.10.09 09:14:38 872 ms
--Last update from peer : (130903) seconds, (238) msec
--Destination : 192.168.1.2
Best regard,
Marco.
Solved! Go to Solution.
10-09-2014 02:39 AM
What's in the routing table for the vrf keepalive?
Can you ping 192.168.1.2 from 192.168.1.1 from within that vrf?
Don't forget to rate all helpful posts.
10-09-2014 02:39 AM
10-09-2014 07:52 AM
friend I can´t do ping
10-09-2014 11:34 AM
You dont have any route in VRF keepalive that is used to route the VPC keepalive traffic. Check the config of VPC domain 1, its using vrf keepalive to ping. Please can you make sure you are using " default route " or some sort of routing to get the traffic through the VRF.
Where is the routing happening for VRF keepalive, are these back to back connected. Try using the route like in VRF management
HTH,
-amit singh
10-12-2014 10:29 AM
I resolve the problem.. the conexion is back to back.. and config was right.. but i have to reload the nexus and the vpc start to work.
thank for all.
