require FI 6120 recovery procedure
I am trying to add FI in existing single system to form cluster
While doing it, the new FI get failed and comming to loader prompt.
It is not showing any folders in it e.g. bootflash, lost+found etc.
If I set ip and gateway, it works temporarily.
After restating using reboot command it looses those ip details.
before the activity FI was tested and shows proper working
please guide for recovery process at this stage
Prakash
Hello Prakash,
If you still have the issue, please open a TAC service request as we need to load the kick start image to start the recovery process.
Padma
Hi Padma,
We opened case with TAC and resolved it.
All the basic files were lost.
We manualy loaded kickstart, system and UCS manager bin files to reconstruct the FI.
After making it ready we then loaded the latest FW codes, (Same as per working FI)
After complete recovery the FI was added as Subordinate member of FI cluster.
We then shut down Master FI to verify the failover.
Now everything is working fine.
Prakash
Prakash,
Glad to hear that it is up and running.
Thanks for sharing the resolution.
Padma
695
