Upgrade of NX-OS from 5.0(2)N1(1) to 5.1(3)N2(1c)
                   Hello Guys!
                    I just like to ask for your help to find out the exact link for the document to upgrade NX-OS from 5.0(2)N1(1) to 5.1(3)N2(1c).
                    I'm facing problem when I add Nexus 2248TP-E-1GE to the existing server farm having Nexus 5548P and Nexus2248TP-1GE.
                    I found out that 2248TP-E is not supported by the existing NX-OS.
                    Thanks.
This is the upgrade guide of this version:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/upgrade/513_N1_1/n5k_upgrade_downgrade_513.html
Why you don't go to nxos version 6.0 or 5.2?
This is the recomendation.
Can I Upgrade directly or jump from version 5.0 to Version 6.0 ?
Thanks.
Hello dorsia,
You can do a disruptive upgrade to any version.
Just in case of ISSU (In service software upgrade) you must follow the specific path of versions.
Anyway, before the upgrade, take a detailed reading of the release notes, because some features may have changed.
Richard
661
