06-11-2016 05:19 AM - edited 03-03-2019 08:15 AM
Hi there Guys
I have a cisco 2621 router. It has worked before, although now it is coming up with the following message during boot up:
System Bootstrap, version 12.2 (8r), Release Software (fc1)
Copyright (c) 2003 by Cisco Systems, Inc
Then I get ERROR No system Memory detected.
I have 32Mb of flash installed and 2*128 NVRAM on the board.
Can someone help me and tell me why I a
06-12-2016 12:21 AM
That is a very old router. I would guess the memory has died from old age, especially since it happened on a restart.
You could try removing and reseating the memory but I don't like your chances.
06-12-2016 01:28 PM
If you just bought the memory last week and it has stopped working you should go back to the supplier.
What interfaces are you using on your 2621?
06-12-2016 10:10 PM
tried the memory in a working unit and the Nvram and flash are detected ok in my working router. I am using console interface at the moment and the display comes up with bootstrap 12.2 (8r) and then I get ERROR No system memory detected. Do you think the board might be the fault?
06-12-2016 10:14 PM
I woudl say that is a very good possibility.
What interfaces are you using in your 2621?
06-13-2016 12:42 PM
I removed the rom chip, all memory and interface cards and moved them to a working 2621 I have. They all work perfectly in that one. Only thing left is power supply and circuit board. Might be a faulty circuit board. Thanks Chris
06-12-2016 01:14 AM
Thanks Philip. I bought the memory new last week as it was an upgrade from the 64mb that was in it originally. I have reseated the memory but not worked. I do have another similar router, so could try the memory from that.
