10/100/1000 module for Cat 4006
Hi Sir,
My customer has two Cat 4006 chassis and are operating in good conditions. Since Cat 4006 has reached its EOS, my customer would like to know any Cat 4500 modules can be used to fit into the exsting Cat 4006 chassis.
He is plannig to have WS-X4424-GB-RJ45 installed into the Cat 4006 chassis. DO you think it will work without any problem? How can I check and verify this?
The modules currently installed are Slot 1 - WS-X4013, Slot 2 - WS-X4418 and Slot 3 - WS-X4232-L3. Both chassis are installed with the same type of modules.
Thank you.
Delon
1 REPLY
Re: 10/100/1000 module for Cat 4006
Yes.. You can use WS-X4424-GB-RJ45 in any CAT4k chassis including 4006 and 4003 chassis.
102
