10 Base- FL Module for 6509 /4507
Hello ,
Is there a 10 Base-FL module for 6509 /4507 ?. Currently , we have a shared Network for our Automation Network , planning to upgrade to Switched Network based on 6509 platform. Most of the Automation systems have Thicknet Interface (10Base-5 with AUI Interface ) connected using 10 Base-FL to AUI media converters (Tranceivers ) .What is the best way to connect Automation system in New Network based on 6509 Platform . Just FYI , we can't change AUI interface on Automation system and it does not have/support 10 Base Tx / 100 Base Tx or 100 Base-FX.
Raju
Gold
Re: 10 Base- FL Module for 6509 /4507
Yes, there is a 10BASE-FL module for the 6500 chassis: Cisco part number WS-X6024-10FL-MT (24 ports, each can do 10 half or 10 full duplex, uses MT-RJ connectors, list price US$12,995). As far as I know, there is no dedicated 10FL card for the 4500 series chassis.
The module is rather expensive, for 24 ports of fiber Ethernet. A less expensive and more flexible solution is to use copper ports, and convert media to fiber.
If you have a 48-port 10/100 module in the 6509, you can disable autodetect of speed and duplex on as many ports as you need, and manually set them to 10 half. Then, use a Category 3 or better patch cable to connect to a 10BASE-T to 10BASE-FL media converter.
If you need many 10BASE-FL connections, then instead of a few standalone media converters you should consider a rack-mount solution. There are several manufacturers which make these; Transition Networks is the one I would recommend (http://www.transition.com). They have a rack-mount conversion shelf that hold up to 18 or 19, and the shelves can be daisy-chained for management purposes.
This will be a more cost-effective solution than the module that installs into the 6500 chassis; but the module would be a more elegant solution.
If you don't already have a 48-port 10/100 module in your 6509, you can still buy one and install it. However, if you do have GBIC ports available, it is less expensive to purchase a Catalyst 2950G-24 or -2950G-48 and the GBICs to connect it to your chassis. Then, use the media converter approach outlined above. (Of course, a 10/100 chassis module would be the more elegant solution.)
In general, 10/100 ports are more useful and are a better investment than dedicated 10BASE-FL ports. As long as you need maintain some sort of 10BASE-FL connectivity, they can be configured to serve that purpose now with the media converters. And you can convert just as many as you need. Later, when you don't need them for 10FL, you can reconfigure the ports back to 10/100 auto and use them for something else.
Hope this helps.
Thanks . We want to avoid/reduce media converters as much as we can . My query is , is there a 10 Base-FL module (cost is not a factor ) for 6509 . I know that there is 100 Base -FX module for 6509 . Similarly , is there a 10 Base-FL module or any stand alone Switch with 10 Base FL ports like 3550-24 -FX model which has 24 Port 100 Base -FX ports . We are talking about more than 60 connections which are currently using 10 Base-FL to AUI media converters , connected to PLC Automation systems.
Gold
60-plus 10FL connections? Wow. If money is no object, then the 6500 series module is what you want. (See my previous post for part number and details; I was editing it when you replied.)
You're going to make a Cisco salesperson very happy...
Thanks . Your information was great . We will buy 3 Modules (10 Base FL i.e 3x24=72 ports ) sothat we will get extra ports for future expansion also and keep some ports as spare .
Dear,
We the leading manufacturer of optical fiber communications in China,our major products include Media Converter,E1 converter,E1 Optical modem,E1 Multiplex,Optical Modem,Base-Band Modem,GBIC,SFP and so on,many famous brands are OEMed from us,We cooperate with worldwild leader corp in this field,Transition networks,Luminent are our important partner,so can also provide theirs products to you at lower price, we have a strong team to design,develope,invent new products for market,Hope to cooperate with you in no distant future,looking forward to your reply,Thanks very much.
Sincerely,
Best Wang
Sales engineer,CCIE
Lightrend technologies,Inc.
Tel: +86 755 83688975 or 83688261 or 83688983
Fax: +86 755 83689111
Mob: 13537574464
Web: www.lightrend.com
Box: best@lightrend.com
MSN: adolf_7@msn.com
ICQ: 280186785
291
