Community Member
10 gig xceiver in Sup V 10Ge Sup Engine
I am using an X2-10GB-LR 10 gigabit singlemode xceiver in a Sup V 10GE engine. I am getting low levels across my link. I would like to know if there is any means of optimizing the optics. Via software or otherwise. I have verified that I am transmitting at a level well within the Cisco documented acceptable range, but it would be very helpful if I could tweak it to be as close to the max level as possible.
Presently I cannot find where I could do that or any documentation that supports the ability to do that.
Thanks in advance
1 REPLY
Silver
Re: 10 gig xceiver in Sup V 10Ge Sup Engine
112
