Webcast-Catalyst9k
1000base -T on 2948g Switch
Will a 2948g switch support the 1000Base-T GBIC
modules? I've been having problems trying to get the switch to detect the them. Do I need to upgrade the system software?
Any help would be great..
TIA
1 REPLY
Re: 1000base -T on 2948g Switch
If it has a physical socket to plug it into, most likely, yes. And old software is the main reason why modules aren't recognized.
117
