Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
12K Port-channel Problem
Hello Everyong,
I'm trying to create a port-channel on my cisco 12K router and getting this error message.
Could some explain to me why this isn't working?
12Kconfig)#interface  GigabitEthernet5/1/0
12K(config-if)#channel-group  2
Error: not supported on  GigabitEthernet5/1/0.
Please and Thank you
1 ACCEPTED SOLUTION
Re: 12K Port-channel Problem
We are running  12.0(32)SY4 whereas the supported platform for this as per document is 12.0(33)S.
thanks,
Vinay
______________
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
Thanks & Regards
i found one previous issue with the same error and it was found that LinkBundling on Engine 5
interfaces is supported from 33S release only.
More info:-
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/lnkbndl.html#wp1279546
So this feature is supported in 33S.
thanks,
Vinay
Thanks & Regards
And thanks for the response, especially for the link.
However, I'm running:
Version 12.0(32)SY4
So it should be supported no?
thanks,
Vinay
______________
Thanks & Regards
228
