eso
1401 <- cross over cable -> 1401
Is it possible to connect 2 1401's ATM-25 without any ATM Switch ?
Edward So
Re: 1401 <- cross over cable -> 1401
Yes,
I'm assuming you are using copper here?
pin cross-overs are:
PIN 1 to 7
PIN 2 to 8
PIN 7 to 1
PIN 8 to 2
pins 3 - 6 are not used.
If fiber, just swap your transmit and receive pairs.
Happy Switching,
~rlc
CCNP, CCDA, CNE
eso
How about the config ? Is this OK ? Do I need to set the internal clock ?
Router A
interface atm 3/0
ip address 192.168.1.10 255.0.0.0
no keepalive
atm clock internal
pvc 1/35
protocol ip 192.168.1.20 broadcast
Router B
interface atm 3/0
ip address 192.168.1.20 255.0.0.0
no keepalive
atm clock internal
pvc 1/35
protocol ip 192.168.1.10 broadcast
eso
Or this config. Which one is right ?
int atm0
ip add 192.168.1.1 255.255.255.0
atm pvc 1 0 32 aal5nlpid
map-group 1
map-list 1
ip 192.168.1.2 atm-vc 1 broadcast
Both configurations are correct, only difference is that one is according to new command syntax, and other is according to old syntax.
eso
Realy work. THANKS
IOS (tm) 1400 Software (C1400-NSY-M), Version 12.1(5)T12, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Mon 04-Feb-02 12:39 by ccai
Image text-base: 0x02005000, data-base: 0x0288EF78
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
ROM: 1400 Software (C1400-RBOOT-R), Version 12.0(3)T, RELEASE SOFTWARE (fc1)
r1401-1 uptime is 28 minutes
System returned to ROM by reload
System image file is "flash:c1400-nsy-mz.121-5.T12.bin"
cisco 1401 (68360) processor (revision A) with 13312K/3072K bytes of memory.
Processor board ID 19783292, with hardware revision 00000002
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
System/IO memory with parity disabled
8192K bytes of DRAM onboard 8192K bytes of DRAM on SIMM
System running from RAM
7K bytes of non-volatile configuration memory.
16384K bytes of processor board PCMCIA flash (Read/Write)
r1401-1#sh atm vc
VCD / Peak Avg/Min Burst
Interface Name VPI VCI Type Encaps SC Kbps Kbps Cells Sts
0 1 1 35 PVC SNAP UBR 25600 UP
r1401-1#sh run
Building configuration...
Current configuration : 675 bytes
version 12.1
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname r1401-1
logging rate-limit console 10 except errors
ip subnet-zero
no ip finger
interface Ethernet0
ip address dhcp
no ip route-cache
no ip mroute-cache
interface ATM0
atm vc-per-vp 4096
no atm ilmi-keepalive
pvc 1/35
protocol ip 192.168.1.1 broadcast
protocol ip 192.168.1.2 broadcast
router rip
network 192.168.0.0
network 192.168.1.0
ip classless
no ip http server
line con 0
transport input none
line vty 0 4
login
end
r1401-1#ping 192.168.1.2
Sending 5, 100-byte ICMP Echos to 192.168.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/6/8 ms
145
