Webcast-Catalyst9k
1538 hub
having problems with cables over 40 feet on hub
link light blinks amber and no connection is established
1 REPLY
Re: 1538 hub
According to: http://www.cisco.com/univercd/cc/td/doc/product/10_100hb/1538m_mh/icg/specs_cb.htm#28048" the Category 5 cable connecting the two Micro Hubs is limited to a distance of 5 meters" You're attempting to run better than 12 meters before failure.
89
