1600 Series Security Problem Help!!!
Given this configuration on my 1600 router that handles a partial frame relay connection, how can I secure the connection to only allow SMTP email to come in and out. I do not use the connection for anything else.
Current configuration:
version 11.2
no service udp-small-servers
no service tcp-small-servers
hostname SCH
enable password
ip subnet-zero
ip nat pool sch1 208.1.217.11 208.1.217.126 netmask 255.255.255.128
ip nat inside source list 1 pool sch1 overload
interface Ethernet0
ip address 208.X.217.1 255.255.255.128
ip nat inside
no logging event subif-link-status
interface Serial0
no ip address
shutdown
no fair-queue
interface Serial1
no ip address
encapsulation frame-relay IETF
bandwidth 128
service-module t1 timeslots 1-2
frame-relay lmi-type ansi
interface Serial1.16 point-to-point
ip address 207.X.149.94 255.255.255.252
ip nat outside
frame-relay interface-dlci 16
ip classless
ip route 0.0.0.0 0.0.0.0 207.42.149.93
snmp-server community sprint RW
line con 0
password
line vty 0 4
password
login local
end
Bruce
  • Other Network Infrastructure Subjects
Silver
Re: 1600 Series Security Problem Help!!!
You can accomplish this by creating 2 extended access-lists (inbound/outbound) and apply these in Serial1.16 point-to-point (in/out).
Lets say you have a mail server with ip address of 208.X.217.10. Here is how the config should look like:
access-list 101 permit tcp any host 208.1.217.10 eq smtp
access-list 102 permit tcp host 208.1.217.10 any eq smtp
ip access-group 101 in
ip access-group 102 out
If you have a static nat defined for mail server, please make sure to use the NATTED ip in the ACL rather than actual ip.
That worked and saved lots of reading. One more problem: I found that I have to let an application that runs on port 9006 in. It's a remote access application something like PC anywhere called NetAccess. How would I allow that port on incoming and outgoing?
Thanks so much!
Bruce
Silver
Bruce,
Here is what you need to add for port 9006 in your existing acl.
access-list 101 permit tcp any host NetAccess_ip_address eq 9006
access-list 102 permit tcp host NetAccess_ip_address any
Mynul
81
