1602 boots to rmon then can boot straight to IOS with manual command
I have a 1602 R that boots to rmon mode when power on reset is performed. Can boot straight to IOS from the rmon prompt. Config reg 0x2102 looks ok as well as system boot flash:c1600-y-mz.120-12 command. Does anyone know if I'm missing something in the boot setup or has anyone seen this problem before? I do have a modem setup on the console port for remote managment.
IOS (tm) 1600 Software (C1600-Y-M), Version 12.0(12), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Mon 10-Jul-00 19:59 by htseng
Image text-base: 0x02005000, data-base: 0x0245E484
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
ROM: 1600 Software (C1600-RBOOT-R), Version 12.0(3)T, RELEASE SOFTWARE (fc1)
Name Removed uptime is 4 days, 3 hours, 11 minutes
System restarted by abort at PC 0x20E7908
System image file is "flash:c1600-y-mz.120-12"
cisco 1602 (68360) processor (revision C) with 6144K/2048K bytes of memory.
Processor board ID 22641869, with hardware revision 00000004
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
On-board Switched 56K Line Interface.
System/IO memory with parity disabled
8192K bytes of DRAM onboard
System running from RAM
7K bytes of non-volatile configuration memory.
4096K bytes of processor board PCMCIA flash (Read/Write)
Re: 1602 boots to rmon then can boot straight to IOS with manual
Could be an electrical issue with capacity that draws a line low for long enough to be seen as a BREAK. Try to boot without the modem attached and see if the problem goes away.
I was thinking along the same lines. The site was a production site and I had a tech swap aout the hardware and when the problem didn't go away I had them send it to me to test in the lab. I'll post the results.
265
