Webcast-Catalyst9k
1604 Ethernet Duplex Capabilities
I am trying to determine the duplex capabilities of the Ethernet interface on a Cisco 1604 router. IOS versions 11.2 and 11.3.
Any info or references would be appreciated.
Thank You,
Dan
Re: 1604 Ethernet Duplex Capabilities
I'm afraid the "duplex" command (see http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123tcr/123tir/int_d1gt.htm#1139668) is not supported on 1600 routers with IOS 11.
If you go to config, int e0, and try to find any command enabling full-duplex, there is nothing.
No mention about the full-duplex possibility on CCO.
Milan
Thanks, Milan. That is why I started this conversation in the Networking Forum; I could find no reference to the duplex configuration on the 1604. I don't encounter these devices or OSes this old very often anymore, but I thought I remember not being able to configure full duplex in some of the older operating systems.
Dan
125
