Community Member
1720 router WIC-2AM dialup problems
I am currently trying to use a Cisco 1720 router with a WIC-2AM card. The problem I have is that line 2 can connect but line 1 doesn’t (the WIC is in the WIC0 slot). I have tried 2 of these cards in the 1720 and neither of them work. These cards have both been tested in a 3660 and have worked fine. I have stripped the configuration down to bare bones and tried reverse telnet to each of these lines and still have the same problem. I am currently using the 12.2(4)YB for my IOS. Any help would be appreciated.
line 1 2
exec-timeout 0 0
modem InOut
transport input all
transport output pad udptn telnet rlogin
autoselect ppp
stopbits 1
speed 115200
flowcontrol hardware
Router#telnet 192.168.121.1 2002
Trying 192.168.121.1, 2002 ... Open
atz
OK
atdtXXXXXXX
CONNECT 115200/V90/LAPM/V42B/26400:TX/45333:RX
Router#telnet 192.168.121.1 2001
Trying 192.168.121.1, 2001 ... Open
atz
OK
atdtXXXXXXX
NO CARRIER
Bronze
Re: 1720 router WIC-2AM dialup problems
To me looks like a bad WIC0 slot as two different WIC-2AMs can not have the same port 2 bad. Did you try WIC1 slot ?
~Zulfi
Community Member
Originally I tried the card in the WIC 1 slot with a WIC-2T in WIC 0 slot and still had the same problem.
145
