Webcast-Catalyst9k
1720 Routers over 2 x BT EPS9 (Baseband) lines using WIC-2T ???
We currently have two Cisco 1720 routers running IOS 12.2(11), connect to each other over a BT Baseband line. The speed on this line is limited to 2MB, we are therefore getting a second line installed, and want to combine the two lines.
I just wanted to double check that this could be done using the following:
WIC-2T - 2 port serial card.
Have each serial port running to a separate Line Driver, and configure the routers to use Multilink via virtual.
Any advice appreciated.
Daniel
1 REPLY
Re: 1720 Routers over 2 x BT EPS9 (Baseband) lines using WIC-2T
Ofcourse u can bundle the E1s connecting on the WAN ports using multilink bundle.
Also u can try out normal load balancing via both the links using normal static routes.
i m not sure what do u mean by "Seperate Line Driver here" ....
regds
169
