1720 w/T1 Installation/Routing Problem
I can ping the router from inside of my LAN or from the internet (outside)
From the router I can ping all the machines on my LAN.
From the 1720, I cannot ping my ISP's gateway or anything on the internet.
pingability
1720 -> LAN Yes
LAN -> 1720 Yes
Internet -> 1720 Yes
1720 -> internet NO
Here's my configuration, any ideas?
for serial0 and the ethernet i have:
nterface FastEthernet 0
no shutdown
description connected to EthernetLAN
ip nat inside
keepalive 10
interface Serial 0
no shutdown
description connected to Internet
service-module t1 clock source line
service-module t1 data-coding normal
service-module t1 remote-loopback full
service-module t1 framing esf
service-module t1 linecode b8zs
service-module t1 lbo none
service-module t1 remote-alarm-enable
ip address 206.119.25.250 255.255.255.252
ip nat outside
encapsulation hdlc
------------------ show running-config ------------------
Building configuration...
Current configuration : 1295 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname cisco
enable secret 5
memory-size iomem 15
ip subnet-zero
ip host-routing
ip name-server 192.168.1.250
ip dhcp excluded-address 192.168.1.150 192.168.1.180
ip dhcp pool 1
network 192.168.1.0 255.255.255.0
domain-name heretic.ws
default-router 192.168.1.1
dns-server 4.2.2.1 4.2.2.2 4.2.2.3
interface FastEthernet0
ip nat inside
speed auto
half-duplex
interface Serial0
ip nat outside
router rip
version 2
passive-interface Serial0
network 192.168.1.0
no auto-summary
ip default-gateway 206.119.25.249
ip nat inside source list 1 interface Serial0 overload
ip classless
ip route profile
ip route 0.0.0.0 0.0.0.0 Serial0
ip route 192.168.1.0 255.255.255.0 FastEthernet0 permanent
ip http server
access-list 1 permit 192.168.1.0 0.0.0.255
snmp-server community RO
line con 0
exec-timeout 0 0
password
login
line aux 0
line vty 0 4
password
login
no scheduler allocate
end
Re: 1720 w/T1 Installation/Routing Problem
Are you using IOS version 12.2.2XK? If so you may find that default routes pointing to an interface don't work!!
i.e. ip route 0.0.0.0 0.0.0.0 Serial0
If so, upgrade the IOS and have another go
This may not be the prob of course but worth mentioning.
Also, when you run a trace from the router to a website, where does it stop?
Ali
Using IOS Version 12.2(6).
Trace hits the router but does not report back the IP address of my ISP's gateway. So it looks like it hits the 1720 and then stops.
In the meantime, I'll trying upgrading the IOS.
OK,
run these:
debug ip icmp
debug ip packet detail
try ping/trace again and see what results you get
97
